Peculiar Problem With T12 Ballasts... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2013, 03:37 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I see the 2 blue wires wired to the line input connections. The only connectikns to the white and black should be the line voltage. Likely ballasts are toast.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
ArkAngel06 (01-11-2013)
Old 01-09-2013, 03:44 PM   #17
Originally Posted by Jim Port View Post
You have the ballast inputs wired to the outputs. You need the incoming power going to the whites and blacks on one side of the ballast.
Just like Tim says disconnect the blue wires we gotta start doing it right.ok the red wire Is wired correctly the problem lies on the other side whrere the blue wires are supposed to go ...you say there's already a black live wire connected here right? In that case disconnect that wire cap it and c9nnecy one blue wire to each connector also get rid of that jumper across the connectors
RAUL HIDALGO is offline   Reply With Quote
The Following User Says Thank You to RAUL HIDALGO For This Useful Post:
Old 01-09-2013, 03:53 PM   #18
But I wouldn't know where to start with this. Both black wires and both white wires go into a socket on each fixture. You would have to pull those out of the socket, put a new blue wire in each one, and carry the white and black to the ballast. Then how would the next fixture get power? Run a a third wire from the ballast to the next fixture? Do you see the problem here?
ArkAngel06 is offline   Reply With Quote
Old 01-09-2013, 04:16 PM   #19
Licensed electrician
Rewards Points: 1,250
Where are the wires that supplied power to this fixture? I can see an empty knockout, but no wires.
Old 01-09-2013, 04:23 PM   #20
I had the same problem a few weeks ago. I understand what ur saying but your are going to have to do some work to make it work.......
Old 01-09-2013, 05:12 PM   #21
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Old ballast used to wire the neutral wire through one or both tubes.
Forget the wire colors on the sockets and wire them just like the diagram.
The Following User Says Thank You to jbfan For This Useful Post:
Old 01-10-2013, 04:23 AM   #22
" Euro " electrician
frenchelectrican's Avatar
The oringal black et white conductors which they go to the tombstone that is the circuit inturpter please disconnect that and cap it off with wirenut and follow the rest with the diagram as it showen on the ballast.
This is a common mistake which I have see some ballast can get toasted up like that so do as I posted or get new tombstone without circuit inturpter in there.
That is the only way you can slove with the slimlines ( they are the only one with CI's beside a handfull oddball size )
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
ArkAngel06 (01-11-2013), mpoulton (01-11-2013)
Old 01-10-2013, 09:43 AM   #23
Rewards Points: 1,294
In the secon picture you posted I see the Blue wires connected to the black and white line in wires along with one other wire in each one. Those black and white line wires need to be connected only to the incoming power feeds. I am surprised that you even get a lamp to light at all with the way it is configured.
As much as I hate to say this, you are in way over your head. I saw the problem in the second picture after looking at it for about 3 seconds. You may want to get someone in there that can help you with this.
danpik is offline   Reply With Quote
Old 01-10-2013, 11:31 AM   #24
Rewards Points: 78
STOP!!!!!!!!!!!!!!!!!
Remove every single wire in the fixture. Remove every single wire attached to the lamp holders.
Rewire the ballast and the tombstones (lamp holders) exactly as shown on the ballast drawing.
You have it wired WRONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You cannot go buy how they were originally wired. Start over or get someone that can follow a simple wiring diagram.
J. V. is online now   Reply With Quote
Old 01-10-2013, 12:31 PM   #25
Missouri Bound's Avatar
How they were originally wired is wrong....that's your problem. Wire them exactly like the ballast shows....not how they were.
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
ArkAngel06 (01-11-2013), J. V. (01-11-2013)
Old 01-10-2013, 07:19 PM   #26
Sparky
Rewards Points: 510
the older magnetic style ballasts did run the hot/neutral through the tombstones, those are no longer manufactured, electronic ballasts(what you have) do not wire the same.
Techy is offline   Reply With Quote
The Following 2 Users Say Thank You to Techy For This Useful Post:
Old 01-10-2013, 09:25 PM   #27
Rewards Points: 506
jlmran is offline   Reply With Quote
Old 01-10-2013, 10:59 PM   #28
Didn't anyone read this is the first post?
The wiring is a little different, but we wired them up the way the diagram says.
Old 01-10-2013, 11:07 PM   #29
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
Is it just me, or is there evidence of something getting too hot. Clues....bubling paint on the fixture....one one of those black wires looks like it maybe got a bit too hot.
Old 01-10-2013, 11:24 PM   #30
Rewards Points: 506
Store? Commercial setting? Where are all the regulars who admonish the non-professionals for working on non-residential electricity?
My personal opinion is that after looking at the pictures I'm not sure that I buy the story that one lamp would light. Especially the 2nd picture.
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
connecting two T8 ballasts in a 4 lamp system DiverDoc Electrical 12 07-21-2010 09:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
