-   -   Peculiar problem with t12 ballasts... (http://www.diychatroom.com/f18/peculiar-problem-t12-ballasts-168674/)
ArkAngel06 01-09-2013 11:11 AM
We own a store that was made some 30 or 40 years ago, and all the fluorescent lighting used magnetic ballasts. They are t12 60w.
Now days they seem to just have the electric ones, so we bought some of them. The wiring is a little different, but we wired them up the way the diagram says. The problem is that only one bulb lights up. The really wierd thing is that if the right bulb lights up, and then you switch the bulbs, the same bulb that originally lit up will light up again on the other side, and the other bulb is out.
So that's probably the bulb that's bad, you say? Nope, we have changed 3 ballasts, and they all do this same exact thing with a myriad of different bulb combinations, most of them being brand new.
The ballasts are for 96"x2 t12 bulbs, and that's what we have. The bulbs are 60w, and the ballast output is 277w. The magnetic ballast output was 750w.
The differences in the magnetic ballast wiring, and the electronic ones are as follows.
Magnetic had 4 wires. 1 white, 1 black, 1 red, and 1 blue. The sockets also had 1 of each color, and the wires just went to the corresponding colors. Red to red, blue to blue, etc.
Electronic ones have 5 wires. 1 white, 1 black, 1 red, and 2 blues. The white goes to white, the black to black, the red to blue+red, and 1 blue goes to black, and 1 blue goes to white.
I am so lost here, please help :huh:
jbfan 01-09-2013 11:23 AM
Post the number on the ballast.
ArkAngel06 01-09-2013 11:45 AM
Sure, ballast says:
Multi-Volt
ProLine T12
ge260is-mv-n-diy (the I after 260 may be a 1, I really can't tell)
Product code: 74475
That is from a GE brand ballast, we also bought a Phillips brand ballast (that also had the same wiring) that did the same thing.
The bulb numbers are f96t12. 60w.
J. V. 01-09-2013 11:58 AM
A warm (excited) lamp will light much easier than a cold one. So if the lamp lights and then you move it, chances are it will light before the cold lamp will. I am am taking an educated guess. So lets perform an experiment.
Mark the lamps and turn off power to the ballast. Remove the lamps and allow them to reach the exact same temperature. Then try reinstalling to see if your problem is the same. To see if it is indeed because the lamp had been warmed up. Check my theory.
Its worth a try.
Are you wiring the new electronic ballasts according to the drawing on the ballast? I have replaced literally hundreds of magnetic with electronic without the issues you describe.
47_47 01-09-2013 12:18 PM
1 Attachment(s)
White and black are the power leads. Blue goes to one side of the bulb lamp holder. The red goes to the other side of the bulb lamp holder. Jumper the red to the other lamp holder on the same side of the bulb.
jbfan 01-09-2013 12:39 PM
You probably have ruined the new ballast by putting line voltage on the output side.
Follow 47_47's diagram
ArkAngel06 01-09-2013 12:41 PM
Its worth a try.
That is definitely not how it works, as I just unplugged the cold one and immediately plugged it back in and it lit up while the warm one was off. It seems a little random, but it will usually follow the one that initially had the power, but not always.
As for the diagram, yes, I followed the one on the ballast, although there are some differences in the diagram and the sockets. The sockets only have one wire each, while the diagram shows 2 wires for each. However, the colors are going to to the correct places.
Also, for each segment of lighting there is 2 black and 2 white wires. Both blacks carry power, but 1 black and 1 white go straight through while 1 white and 1 black go to 1 socket each. I have tried hooking the ballast up to either black and white with the same result.
ArkAngel06 01-09-2013 12:44 PM
That diagram is the same one from the ballast, and that is how I hooked it up. Read my last post to see why the output may have gotten power, but how I really couldn't help it.
jbfan 01-09-2013 12:44 PM
Pics of the wiring will help us.
ArkAngel06 01-09-2013 12:58 PM
I will take some and upload them when I get home in an hour or so.
RAUL HIDALGO 01-09-2013 01:03 PM
Yeah some pics would get you the right answer faster.
47_47 01-09-2013 01:05 PM
If this place is like one I rented, do not follow the existing colors. Many times they used what ever wires they had when changing a ballast, ignoring colors. As jbfan stated pics would help.
ArkAngel06 01-09-2013 03:02 PM
Yes, I didn't follow the coloring, I went purely by the diagram.
Here are the pics.
http://i.imgur.com/GZCtA.jpg
http://i.imgur.com/4HhaM.jpg
http://i.imgur.com/h0TCH.jpg
http://i.imgur.com/IDOSZ.jpg
http://i.imgur.com/weGtD.jpg
http://i.imgur.com/ebicK.jpg
Jim Port 01-09-2013 03:32 PM
You have the ballast inputs wired to the outputs. You need the incoming power going to the whites and blacks on one side of the ballast.
ArkAngel06 01-09-2013 03:34 PM
As you can see in the last picture, both black wires are connected at the socket, and one goes to the ballast, and one goes to the next fixture.
The power wires, and the outputs are the same wire. This doesn't make much sense to me, but that's how they were originally wired up.
