Patching A CableTV/Internet Ground Line - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 01:44 PM   #1
Patching a CableTV/Internet Ground Line
I was working at a clients house and managed to cut the thick ground line from their cable provide. They had it no more than 6 inches under the surface…. It will be 10+ days before a technician from the company can come out and take care of this and the client wants to know if I can do a temporary patch of some sort. Has anyone worked with these? This isn’t normal Coax, it’s a very thick cable with a large copper wire in the middle, insulation foam, a metal exterior coating and then rubber on top of that.
Could I just run a copper patch from the one side to the other or does the metal coating transfer something as well? Any help would be much appreciated!
jpf566 is offline   Reply With Quote
Old 04-23-2012, 01:51 PM   #2
Rewards Points: 13,300
Any I've seen were bare copper wire.
Sounds like they used the wire for running cable line instead for some reason.
(might be what they had on the truck so they used it)
Old 04-23-2012, 02:09 PM   #3
Rewards Points: 2,516
sounds like that may be a locator wire....for locating the cable underground so a person does not run it over
hammerlane is offline   Reply With Quote
Old 04-23-2012, 02:14 PM   #4
Rewards Points: 3,256
You cut the main signal coax which in this case is the larger hard line that they run sometimes. You could try to splice it to get them by but it's not an easy task and their signal might not be good enough to connect.
You will need to patch both the inside and outside.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
mpoulton (04-23-2012)
Old 04-23-2012, 02:14 PM   #5
I=E/R
a7ecorsair's Avatar
Does their cable TV and/or internet access still work?
a7ecorsair is offline   Reply With Quote
Old 04-23-2012, 02:17 PM   #6
The client does not have cable tv, only cable interent, and it does NOT work.
Old 04-23-2012, 02:19 PM   #7
Solder or butt splice the center conductor. I would use small hose clamps on the outer shield with a short jumper wire or better yet some thin metal or foil wrapped around the outside and hose clamped. If that works, tape it up real well.
Old 04-23-2012, 02:28 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,902
The cable you are describing is not the ground wire or a locator wire - it's coax. It looks unfamiliar because it's larger, heavier coax than what's used inside your home.
EDIT: I see that their service is out. You could try to splice it, but it's very unlikely to work well enough. Coax is not merely a wire inside a metal shield. It is a carefully engineered assembly that guides radio waves through it in a precisely controlled manner. The dimensions of the conductors (inner and outer) and electrical properties of the insulation are critical to its proper operation. Any anomaly in the dimensions of the cable or the materials it's made of will result in HUGE signal loss. No matter how careful you are to make the splice exactly the same profile as the cable itself, it will still lose the majority of the signal. You might be able to get enough signal through to temporarily restore service. The only proper solution is to install direct burial rated connectors on the cut ends.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
PaliBob (04-23-2012), Ravenworks (04-23-2012)
Old 04-23-2012, 02:33 PM   #9
Originally Posted by mpoulton View Post
The cable you are describing is not the ground wire or a locator wire - it's coax. It looks unfamiliar because it's larger, heavier coax than what's used inside your home. If everything seems to be working properly, it's possible that the line you cut was an spare or abandoned run.
No, the internet is down, this was definitely the house coax line.
Will I need to splice the copper core & the metal casing or just the core?
Old 04-23-2012, 02:36 PM   #10
I=E/R
a7ecorsair's Avatar
As zappa said, try splicing.
I'd use a small crimp splice on the center conductor, then some electrical tape, then some tin foil from the kitchen held in place with zip ties, then wrap it all in electrical tape.
The Following User Says Thank You to a7ecorsair For This Useful Post:
zappa (04-23-2012)
Old 04-23-2012, 03:19 PM   #11
joed's Avatar
Rewards Points: 12,018
You will need to splice the core and the metal casing to have any chance of it working.
Old 04-23-2012, 03:26 PM   #12
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Use compresion connectors and heat shrink tubing and next time call before you do any digging around someones yard.
if it's rg-11 the connectors are usually not found at your average store you will have to get them at electrical supply. The connectors are about 15 bucks if you only buy a couple then you also need a splice connector some heat shrink tubing and crimper. May be able to strip the cable without also buying a cable stripping tool. May be cheaper to let the cable company do it than spending about 100 bucks in tools and supplies.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-23-2012, 05:03 PM   #13
Just a DIY guy
Cable company said 10 days. That's a long time to go with a homeowner screaming at you.
. if it's rg-11 .
sounds like it. RG-11 has a 14 gauge core wire, used for long-distance applications.
M3 Pete is offline   Reply With Quote
Old 04-23-2012, 05:34 PM   #14
The poster should of snapped a photo of what was damaged
Old 04-23-2012, 05:39 PM   #15
I=E/R
a7ecorsair's Avatar
It was described quite well and also note that the internet is dead.
Main Line Clog Master Brian Plumbing 46 09-06-2012 09:38 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
