Patch Panel, Help ID - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 02:53 PM   #1
Patch panel, help ID
In our new house I have this patch panel (image attached). I'd like to read up on how it is usually set up, how to make changes, etc -- never had one of these before. Any pointers/articles/keywords to google on will be much appreciated.
Thanks!
Andrew.
Patch panel, help ID-img_20110409_180354.jpg   Patch panel, help ID-img_20110409_180404.jpg
AndrewM is offline   Reply With Quote
Old 04-19-2011, 03:21 PM   #2
Mad Scientist
That's your basic 110 punch-down block, wired for phones, with those loopy jumpers connecting all the matching pairs together on all cables.
What do you think you might want to do with it? Each cable terminates at one 8-position clip. You can pull the jumpers out of the slots on a clip to disconnect that cable. Using a standard punchdown tool with a 110 blade, you can then connect your own jumpers to reconnect things as desired, for instance to wire up a home network.
To keep CAT 5 performance and allow 100Mbit Ethernet, keep jumpers as short as possible, avoid sharp bends, and keep the pairs twisted together as close to their terminations as possible.
I realize that's a fair bit to digest, so feel free to ask any more specific questions you might have.
McSteve is offline   Reply With Quote
Old 04-19-2011, 03:27 PM   #3
Mad Scientist
Some more general advice: You'll probably want to invest in a tone generator and probe set to identify which jacks in the house are connected where on the 110 block.
Personally, I would then get a patch panel with RJ45 jacks and mount it below the 110 block. Run cables from the 110 block to the patch panel for each jack you want to use for data. Then you can simply use short network cables to connect each jack to a router or switch, and have a home network ready to go.
Old 04-19-2011, 04:22 PM   #4
Thank you!
That "110 punch-down block" is what I was looking for the most
I can now at least google something. I did not know what it's called and how to look for tools & tips.
That's roughly what I wanted to do -- mount a network switch in there and have all of the cat5's connect to it. May be even the cable modem and router as well.
These loops on top did not make sense to me. I did not realize it is not only cat5, but also phone as well and these loops are just joining all of the phone jacks. It makes sense now.
Old 04-19-2011, 04:29 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you would likely want to install something such as this:
rather than using the 110 block. You would then use patch cords to run from that patch panel to your electronics.
there are many designs of patch panels. You can get smaller or larger panels as well as many different types of design. I just found that pic that showed the use of the panel clearly.
Old 04-19-2011, 04:30 PM   #6
nap
You talking to me?
nap's Avatar
regardless what they are for, it is an ugly ugly installation.
Old 04-19-2011, 04:47 PM   #7
nap - I agree, it does look ugly and not very functional.
There is no power in that box... I guess my project would be to find a way to get power there, then just rip this "110 block" out and install a new patch panel + modem, switch and router. Sounds fun and not too expensive, now that I look at pictures and articles thanks to you and Steve.
Old 04-19-2011, 06:44 PM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
I was just going to suggest this. I find it's much more modular and manageable.
You can get a keystone patch panel then you terminate the run to a keystone which can be for ethernet, phone, cable TV, etc... and simply inserts in the hole, the same way as a jack. It makes a very nice clean install that is also easy to add-on to.
Here's my setup just to give an idea:
Not the cleanest mind you. :P
Old 04-20-2011, 07:43 AM   #9
Rewards Points: 97
If you google "structured media" or "structured wiring", there are tons of articles on the subject.
Some common brands: Leviton, OnQ, Channel Vision
Here's my small on-going project. Most parts from Leviton.
leungw is offline   Reply With Quote
Old 04-20-2011, 10:27 AM   #10
nap
You talking to me?
nap's Avatar
looks nice. I have a question about what you have. In the upper left corner,what are those? They appear to be a 110 type connection for the cables extending to the field but is that an 8P8C jack in the center (with a patch cord to the Netgear switch(?))?
Old 04-20-2011, 10:38 AM   #11
Rewards Points: 97
Thanks. The boards at the upper left are made by Leviton. It has 3 sets of punch downs on each side, and in the middle are 6 RJ45 jacks. The orange big box store sells them for $25 each, but you can often find them on eBay for about $5 each.
Old 04-20-2011, 12:46 PM   #12
Mad Scientist
Here's my setup, such as it is. It's come a long way since this picture was taken, but the principle is the same. The patch panel comes empty, and accepts the same snap-in keystone jacks that are used in the wall plates throughout my house.
New Home Network by mr_steve2009, on Flickr
Old 04-20-2011, 02:23 PM   #13
Hey, that looks really nice, now I have a benchmark to aspire to
I was reading on Leviton yesterday... it sounds good.
Old 04-20-2011, 02:45 PM   #14
Rewards Points: 97
Thanks. Like you, I was inspired by pictures that I saw on the web. Some people really go nuts on these things, and mine's nothing in comparison.
Old 07-23-2012, 11:31 PM   #15
Hey leungw,
That's a very nice install. I have a similar setup, however I'm trying to figure out how to mount all my network equipment. I purchased a few of the Leviton universal shelf brackets but they are pretty flimsy. Your mounting solution for the Netgear switch and modem/router look very solid. Can you tell me how you did it?
PS: I am trying to mount a Actiontec MI-424WR modem, an HP V1410-16G switch, and a Cisco RV042 Router.
Thanks.
htrieu is offline   Reply With Quote
Panel cleanup gdoucette Electrical 5 06-26-2010 02:01 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 12:20 PM
