Passing Coax Through An Exterior Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 07:37 AM   #1
Rewards Points: 150
Passing coax through an exterior wall?
Hi, I need to install an antenna by my garage and have all the supplies. My question is what is the best, cleanest looking way to run the cable through the exterior wall (which is OSB & Hardiplank)?
I've seen some people just drill a hole, run the cable and silicone around. This looks terrible IMO. Is there some kind of plate or box I could put on the outside?
sheslostcontrol is offline   Reply With Quote
Old 12-12-2010, 08:07 AM   #2
There are coverplates for various cable connections that make the job look finished. Check in home, hardware stores.
Old 12-12-2010, 11:07 AM   #3
Rewards Points: 6,652
Go to Radioshack and get a Coax passthrough tube. Looks like a straw with two washers on the end. This is the proper way to pass coax through a wall.
Old 12-12-2010, 11:14 AM   #4
Rewards Points: 150
Found some of these in HD this morning - thanks.
Tags
coax , low voltage
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
How to run new cable to outside? hoggin03 Carpentry 2 08-25-2010 10:29 AM
unwanted voltage on coax sat-man Electrical 4 09-19-2008 08:36 AM
Tips on Running Coax handy man88 Electrical 2 08-29-2008 01:07 PM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
