Old 12-04-2011, 09:17 PM   #1
Pass & seymour legrand surface mount receptacle disassembly
hey guys im trying to replace a pass & seymour 30a 250v receptacle that is surface mounted
unfortunately i removed the four screws but i will not budge. is there an allen wrench in the middle hole that i need to remove? i have no instructions.
also im going to be replacing it with one of these:
so i take it im going to need a steel box to go with it?
ChronPaul is offline   Reply With Quote
Old 12-04-2011, 10:10 PM   #2
Licensed electrician
The center hole between the prong hole is a screw that holds the cover on the backer plate.
Yes you will need a different type of box and trim plate.
Are you running a new circuit for the new receptacle?
Old 12-04-2011, 10:22 PM   #3
Electrician
SD515's Avatar
The one you want to add is a nema 6-15, rated 250v, 15A. You’ll have to use a 2-pole, 15A breaker for it also.
Kyle
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
Welder Receptacle - What Electrical Box SNAFU Electrical 4 10-26-2010 10:45 PM
Where to buy Pass & Seymour Specialty jamiedolan Electrical 6 11-04-2008 12:12 AM
