Partial Power Outage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 03:23 PM   #16
Rewards Points: 14,306
Odd that we have at least three differant poster today all having power problums that all could be cause from incoming power and not one registered with there location.
Old 02-11-2013, 03:25 PM   #17
MarginallyQualified
Rewards Points: 2,464
and all with the same user name
Old 02-11-2013, 03:30 PM   #18
bj1
i apologize I am a new user . sorry.
bj1 is offline   Reply With Quote
Old 02-11-2013, 03:37 PM   #19
Have you called the power company yet to check incoming power?
bj1 (02-11-2013)
Old 02-11-2013, 03:39 PM   #20
bj1
on hold with them now
Old 02-11-2013, 04:45 PM   #21
An old Tradesmen
Rewards Points: 8,184
Merged you threads.
The Following User Says Thank You to beenthere For This Useful Post:
bj1 (02-11-2013)
Old 02-11-2013, 04:49 PM   #22
An old Tradesmen
I'm gonna make a WAG. You got a problem with your neutral between your panel box and meter base. This is a serious issue, and can cause lots of damage. if you get no satisfaction from the power company. Call a qualified electrician quick.
Yes, this is a DIY site. But I just don't think your ready to get involved with pulling the meter and checking. In some areas, only the power company and licensed electricians are allowed to pull it.
bj1 (02-11-2013)
Old 02-11-2013, 06:00 PM   #23
bj1
i have to call the power company back first thing in the morning was told no appointments for checks made after three pm. i hope this problem can be fixed asap. all plugs switches and breakers have been checked and tested . its so strange the power did this the first time on new years eve and corrected itself in minutes and a few days ago it started again. now it will go out from 5 min - an hour or two and then kick back on ??? gonna go to the power company at 8am when they open
Old 02-11-2013, 06:17 PM   #24
dmxtothemax's Avatar
Rewards Points: 5,608
Originally Posted by bj1 View Post
i am experiencing a partial power outage when my hvac unit kicks on . It will not turn on immediately but will cause power to go out in only some of the house. once the unit does kick on the power restores its self what could be causing this problem ?
Please elaborate on "partial power outage"
does it go out completely ?
or just dipp down a bit ?
for how long ?
Sounds like an poor connecttion or overloaded phase.
If your end checks out ok,
then call POCO as it's most likely there problem !
Please let us know the out come ?
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
bj1 (02-11-2013)
Old 02-11-2013, 06:47 PM   #25
bj1
By partial. I mean power is going out only in some areas kitchen plugs out but light on bedroom light out but plugs work. Had all plugs and switches checked no problem. Hvac unit out. I hope the Power company comes tomorrow. All breakers have also been tested. Its so frustrating and scary. I will be sure to keep u posted. If you have any suggestions I haven't mentioned please share. That's so much.
Old 02-11-2013, 10:16 PM   #26
Sounds like a really loose connecttion somewhere.
Heats up, expands, breaks connecttion.
power stops moving, cools down, sometimes
re-establishing connecttion sometimes not !
Hope its not your end !
could be dangerous !
real potential for fire !
bj1 (02-12-2013)
Old 02-11-2013, 10:36 PM   #27
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It's going to suck, but the best thing to do is turn off the main. If the neutral is bad, you risk frying anything electronic and eliminate the possible risk of fire.
The Following User Says Thank You to k_buz For This Useful Post:
bj1 (02-12-2013)
Old 02-12-2013, 12:10 AM   #28
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would call them back and say it's an emergency power situation. Not good to have a bad connection heating up. They have people working all the time tell them to get someone there.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is online now   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
bj1 (02-12-2013)
Old 02-12-2013, 10:30 AM   #29
bj1
update on partial power outage: power company just left there was a connection at the pole that was burnt . worker said there was just enough juice left in line to only support half the power load of the house and eventually the power would have failed in the whole house. line has been replaced and everything in the house came on with no hesitation . I wanna say thank you for all your help and patience with me being a newbee on the site and your assistance has been priceless and I am very thanful for all your help.
Old 02-12-2013, 10:40 AM   #30
rrolleston's Avatar
Great happy that they were able to get you going again. It's much nicer when it's on their end and not yours. Much cheaper too.
bj1 (02-12-2013)
Asko washer won't stop beeping after power outage marytara Appliances 0 07-07-2012 06:50 PM
Running boiler during power outage? jmhultin HVAC 7 10-31-2011 11:28 AM
All wiring underground, yet power outage...? PCMLR Electrical 2 10-10-2010 10:20 PM
power outage jp66hill Electrical 4 01-22-2006 07:24 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
