Parallel Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 03:56 AM   #1
Unhappy
Parallel circuit?
Feeling stupid and was hoping someone might know the answer.
The 6 lights pictured below are each normally meant to be directly hooked into a 9 volt battery and have a resister built into each one of them. An odd project requires me to wire the power to them instead.
Question #1:
Can I safely connect them in parallel so a single switch can turn them on at once?
Question #2:
If so, do 6 batteries need to be used or can a single battery power them for a shorter amount of time?
jove is offline   Reply With Quote
Old 08-02-2011, 04:57 AM   #2
Gbm
They look like led so current draw is minimal. A single battery should work. If life is dramatically reduced then you could also wire several batteries in parallel too.
Gbm is offline   Reply With Quote
Old 08-02-2011, 01:32 PM   #3
Sounds like a plan. Thanks for the reply.
Tags
9volt , battery , circuit , parallel , resister
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Bathroom Fan/Outlets on Same Circuit rjschwar Electrical 6 04-22-2011 10:56 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
