-   -   Parallel circuit? (http://www.diychatroom.com/f18/parallel-circuit-112706/)
jove 08-02-2011 03:56 AM
Parallel circuit?
Feeling stupid and was hoping someone might know the answer.
The 6 lights pictured below are each normally meant to be directly hooked into a 9 volt battery and have a resister built into each one of them. An odd project requires me to wire the power to them instead.
Question #1:
Can I safely connect them in parallel so a single switch can turn them on at once?
Question #2:
If so, do 6 batteries need to be used or can a single battery power them for a shorter amount of time?
http://i827.photobucket.com/albums/z...voneswitch.jpg
Gbm 08-02-2011 04:57 AM
They look like led so current draw is minimal. A single battery should work. If life is dramatically reduced then you could also wire several batteries in parallel too.
jove 08-02-2011 01:32 PM
Sounds like a plan. Thanks for the reply. :thumbsup:
