| joshvette001 |
05-01-2010 09:46 PM |
Panel Upgrade space requirement
1 Attachment(s)
Alright guys I had to register because I want some opinions on this... I have been reading this forum almost every day just reading and observing peoples opinions and obvious knowledge and I have a bit of a issue for this panel upgrade...
Currently as you can see in the picture this Service panel with fuses is a 100 amp panel... We are going to be upgrading the service to a 200 amp GE main breaker box... Only issue I have so far realized is the space requirement... To the left is a hot water tank and I realized that when the original box was installed 20 something years ago that tank was there also just a older one so I'm confused as to how this ever passed inspection unless those space requirements didn't exist than... Anyways I am wondering with the washing machine to the right which we can move over about 3 feet and that hot water tank do you think that a inspector would completely fail a upgrade with a new panel box being where the current fuse box is... or do you think that as long as the washing machine is moved over that he would let it slide even know it is obviously still against code....? Anyways I look forward to hearing some opinions
Thank you ,
Josh
