Panel Swap - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 07:46 PM   #1
Panel Swap
Hey Guys
I want to do a panel swap from 100amp fuses to 100amp breakers. My house is older and some wire is not grounded (old black crap), and some is newer and grounded. When i do the swap and get it inspected, will I be required to put GFI's at the panel to protect each ungrounded circuit?
fendrix is offline   Reply With Quote
Old 11-08-2011, 08:12 PM   #2
Lic Elect/Inspector/CPO
You do not have to put gfi breakers in the panel. The rept that are on any of the non grounded circuits have to be 2 prong or gfi with the sticker no equipment ground.
NJMarine is offline   Reply With Quote
Old 11-09-2011, 11:37 AM   #3
Rewards Points: 58
You actually have to do nothing. The panel change does not affect anything already installed previously. Your inspector most likely will not look at anything but the new panel and the service.
Old 11-09-2011, 11:44 AM   #4
Licensed electrician
Rewards Points: 1,010
I agree with JV. Also the GFI protection would only be needed if you wanted to install 3 prong receptacles on an ungrounded wiring method.
Panel cleanup gdoucette Electrical 5 06-26-2010 03:01 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
