Panel Surge Protector - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 02:03 AM   #1
Rewards Points: 20
Thanks for any advice,
I was considering having a whole house surge protector installed at the panel after reading the article last week on c-net which talked about ways to protect home electronics. The electrician who looked at my panel said I don't have the room for the surge breaker and he needs to piggy back 2 other breakers and move everything up to create space. It doesn't sound to me like the best solution - any thoughts are appreciated.
Thanks,
Just Asking
IJustAsking is offline   Reply With Quote
Old 07-17-2012, 05:16 AM   #2
Rewards Points: 1,192
They make breakers that can do what you want to do. Check your mfg.
bobelectric is offline   Reply With Quote
Old 07-17-2012, 05:57 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks,
Just Asking
If done in the best manner, it might never be an issue, of course, adding a sub panel isn't out of the question either... which is probably the best route to take, since it will allow future circuits to be added.
Old 07-18-2012, 10:26 AM   #4
I don't want to talk surge breakers down because they do have their uses but they are limited in their capability (robustness too) because of space. You will notice that they generally have a 2 or 3 year product warranty. These products are best used for flushmount applications like when the panel is in the kitchen and you don't desire to see a LED light. But for superior protection you generally need a larger unit which, unless you upgrade panel with integral surge protector, leaves you with an external solution.
I could go into a lengthy discussion about surge but to answer your space issue I point out that your electrician can sub out an existing breaker for a tandem breaker to install an external surge protector on. A secondary option is to install a Type 1 listed SPD that does not require a breaker for installation.
Fair warning I work for a surge manuf and recommend our part#s50a120v2p. But, regardless of manuf the above advice is applicable.
surgeknowitall is offline   Reply With Quote
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 08:00 AM
Getting a 200Amp Square D OQ Panel. What about surge protector? mudworm Electrical 3 10-27-2011 02:29 PM
New place, no ground in room, expensive computer pinkmanta Electrical 27 10-24-2011 01:16 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
