Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2010, 08:00 PM   #1
Question
Panel Question
When wiring into your panel, If you know that you have an empty slot for a breaker, How do you know if you have room on your 100 or 200 amp service for the addition of another breaker?
mj876 is offline   Reply With Quote
Old 03-13-2010, 08:04 PM   #2
Each panel is rated for a certain number of circuits
A lot of 200a panels are rated for 40 or 44 (?) circuits
Usually if you have an open space you have room for another circuit
Unless you have used a lot of tandem breakers
Old 03-13-2010, 10:52 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Majorty of panels will list the numbers of circuits it don't matter if you have little 6 space subpanel or monster main 42 space panel {I know canada verison can go alot more but in USA I do not know which states will allow more than 42 from single panel }
Most of 200'ers I ran into typically will come in one of three most common size .,, 20 ,30 ,40 some case 30/40 will show up the 30/40 mean 30 full sized space breakers and can allowed up to 10 tandaem breakers.
Merci,Marc
P.S.
Dave let you know per modern NEC code we are limited to 42 circuits max.
100 amp sub panel question macddmac Electrical 4 02-03-2010 11:11 AM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Service Panel Question??? sv123 Electrical 4 10-06-2008 06:26 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
