Panel Main Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 11:11 AM   #1
Hey guys I have an older Westinghouse/ Bryant type 24-40 BFN-BFS panel that has the main lugged in at the bottom and the main disconnect breaker at the meter. Is it possible to add a main shut-off to the panel and if so 100A double pole? It uses type BR breakers.
Thanks!
flatlander745 is offline   Reply With Quote
Old 10-05-2010, 08:39 PM   #2
dSilanskas's Avatar
If you have a 100 amp panel sure it is. Just get a 100 amp main breaker BR of course.
dSilanskas is offline   Reply With Quote
Old 10-05-2010, 09:06 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Isin't that big one at the bottom a main shut off? Looks like it to me. Also not sure why they did not just flip it over and put it on top, instead of running those giant cables through the whole panel.
Old 10-05-2010, 10:07 PM   #4
Mad Scientist
Nah, that big thing at the bottom is just a lug block, no switch. It can be replaced with a 100A breaker, but you'll need a hold-down kit to ensure it can't simply be pulled off the bussbars.
McSteve is offline   Reply With Quote
Old 10-05-2010, 10:13 PM   #5
Wire Chewer
Rewards Points: 132
Ahh right I see now, no handles. I just automatically assumed it was a breaker.
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
Can I upgrade my main panel? MarkinTexas Electrical 8 01-22-2009 10:15 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 07:43 AM
