Panel Location - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 11:16 AM   #1
Rewards Points: 101
Panel Location
All -
My question is this. I have a hundred year old home with a panel in clear violation of the clearance requirements. My question is when replacing my panel, which has the "out" pipe for plumbing a few inches below it would I have to bring this up to present day code or can this stay as located? I am redoing all the electric in the home, but did not plan on changing the line into the house or the location to the panel. Before I start running my lines to the panel I just want to be sure my panel will be able to stay as located currently. I was supposed to hear back from the inspector to day but like the past 3 Mondays and Wednesdays no call. Is there a type of "renovation code" or grandfather section of the code that would allow me to keep my panel location or will I have to move the panel, meter, supply lines, etc. to bring it up to today's code?
Thanks for any responses.
Tom
I am located in New Jersey.
Thomas
South Jersey - Camden County
tjbingha is offline   Reply With Quote
Old 03-27-2013, 12:00 PM   #2
joed's Avatar
Rewards Points: 12,416
What is the violation that would make it not compliant today? If it is a head room issue that is often overlooked for low ceiling basements.
Old 03-27-2013, 12:10 PM   #3
Rewards Points: 101
Headroom for one, pretty much all the clearance requirements that you could have. I have about 12 inches to one side of the meter before a corner wall, 20 inches or so to window, there is the drain pipe for the kitchen plumbing directly below it. About 5 1/2 foot ceilings. Needless to say it is not in the best spot. There are tons of old houses in the area so I just wish this guy would return my call. I doubt this is the first time this has come up but I am a little stuck on where to move it. My house has no garage, utility room, etc.
No matter where I move it in the basement I will be in violation of some sort. What a pain this part is.
Thomas
Old 03-27-2013, 12:26 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Which town do you live in?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-27-2013, 01:08 PM   #5
Rewards Points: 578
I suppose you could always mount it on the outside of your house, thats the way its done around here except for mobile homes. Or mount it inside a hallway somewhere, or a spare bedroom, office, den. Just needs to have adequate clearance and access. Mounting it outside requires a certain box.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 03-27-2013, 01:14 PM   #6
Rewards Points: 101
***** enough and the world shall provide. The inspector called me back and I will fall under the rehab code and do not have to move the box as long as nothing in blocking working access to the panel. Clearance requirements will not fall into play as these requirements were not around when the work was done. My plumbing pipe will not cause issue.
Thanks for your responses.
Thomas
Old 03-27-2013, 01:17 PM   #7
electures's Avatar
What town?
Old 03-27-2013, 01:34 PM   #8
Rewards Points: 101
No specific requirements for my town, why does it matter?
Thomas
Old 03-27-2013, 01:55 PM   #9
electures's Avatar
I have been an electrical inspector in S. Jersey for 20 yrs. I know most of the inspectors. Follow the links in my signature for a few threads I started specifically for NJ. Post any questions here. Good luck!
Old 03-27-2013, 02:02 PM   #10
Rewards Points: 101
Ok, just not in the habit of calling out inspectors online by name. It is tough in these small towns due to the size of our departments, there is just no availability for them to get back to us at the same time my project has to move forward. Very different from Philadelphia where I moved from. More than anything there is just not as many requirements as NJ.
Thanks, it is a huge renovation and my biggest problems are what falls under the renovation code and what is required under the new code. No where in my house would my panel meet code and I know how tough NJ is hence my panicking.
And I have been through your signatures many times...
Thomas
Old 03-27-2013, 03:59 PM   #11
eastcoastsparky's Avatar
Rewards Points: 150
A town would help, im from pennsauken, there are a couple of us on this site that have worked probably all of south jersey
eastcoastsparky is offline   Reply With Quote
Old 03-27-2013, 04:00 PM   #12
Rewards Points: 150
And a pic
Old 03-27-2013, 04:14 PM   #13
Rewards Points: 101
Thanks for the response, but the inspector has responded. I will post updates and questions as I go about the project...I am sure I will have many electrical code questions.
Thomas
Old 03-27-2013, 04:26 PM   #14
Rewards Points: 150
What did he say, do you have a pic. We may be able to clear up some questions ahead of time
Old 03-27-2013, 06:17 PM   #15
joed's Avatar
The info requested will help others who may have the same issues.
The Following User Says Thank You to joed For This Useful Post:
electures (03-27-2013)
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Svc Panel location near G. Door wannabuild Electrical 1 01-15-2007 08:48 AM
