Old 12-03-2012, 05:24 PM   #1
Panel Loading Question
I have a question and found some similar topics but could not find the specific answer.
I know ideally that a panel should be loaded equally on both legs but i have read on here also that it is not a big deal for residential.
My question is this: Can i put all of my motors i.e. furnace, refrigerators etc on one leg and all of my lighting on the other, then fill in with my wall receptacles? I ask this to try to avoid the annoying dimming of lights when these motors start and kick in. I have reduced some of this annoyance by switching to CFL's which dont seem to mind the split second voltage drop. Obviously I cannot seperate out the AC as this is 240volt.
Just curious if seperating them is an issue or not.
Rick
bcgfdc3 is offline   Reply With Quote
Old 12-03-2012, 05:41 PM   #2
Just put your motors on dedicated circuits and load all the circuits equally across both legs. That should help.
sgip2000 is offline   Reply With Quote
Old 12-03-2012, 05:48 PM   #3
One other question. Does it matter if they are close to the supply? I mean the first breakers or the last on the bus.
I know surge supressors are supposed to be and i didn' know if this would help or not.
Old 12-03-2012, 06:21 PM   #4
No, does not matter.
Surge breakers need to be close to the neutral bus to minimize the length of the wire(s).
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
Sub panel question Dogger Electrical 1 09-28-2011 05:48 PM
Question about sub panel lilryry Electrical 12 07-29-2011 12:32 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 04:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
