-   -   Panel Loading Question (http://www.diychatroom.com/f18/panel-loading-question-165506/)
bcgfdc3 12-03-2012 05:24 PM
I have a question and found some similar topics but could not find the specific answer.
I know ideally that a panel should be loaded equally on both legs but i have read on here also that it is not a big deal for residential.
My question is this: Can i put all of my motors i.e. furnace, refrigerators etc on one leg and all of my lighting on the other, then fill in with my wall receptacles? I ask this to try to avoid the annoying dimming of lights when these motors start and kick in. I have reduced some of this annoyance by switching to CFL's which dont seem to mind the split second voltage drop. Obviously I cannot seperate out the AC as this is 240volt.
Just curious if seperating them is an issue or not.
Rick
sgip2000 12-03-2012 05:41 PM
Just put your motors on dedicated circuits and load all the circuits equally across both legs. That should help.
bcgfdc3 12-03-2012 05:48 PM
One other question. Does it matter if they are close to the supply? I mean the first breakers or the last on the bus.
I know surge supressors are supposed to be and i didn' know if this would help or not.
sgip2000 12-03-2012 06:21 PM
No, does not matter.
Surge breakers need to be close to the neutral bus to minimize the length of the wire(s).
