Panel Layout - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2008, 08:14 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Panel Layout
Sorry to be a pest with questions, I am making progress.
I wanted to find out if it makes any difference where you place your breakers in your panel. Should you put your heavy loads closest to the main?
I don't know if it is true, but I was told once that it can reduce light flicker caused by high inrush current appliances like central AC if they are placed close to the main.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-17-2008, 08:27 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
It doesn't matter AT ALL.
Speedy Petey is online now   Reply With Quote
Old 11-17-2008, 10:20 PM   #3
Idiot Emeritus
Rewards Points: 1,492
As stated above, it makes absolutely no difference. A 10 ton single phase A/C unit starting at the far end of a 40 circuit panel will cause less than 1/10th of a volt drop in the panel busses.
The lights dimming is almost always caused by voltage drop between the POCO transformer and the panel. POCOs everywhere are notorious for using small wire. I can't count the number of times I've seen a 4/0 AL or a 2/0 CU coming out of the mast spliced to a #6 or a #4 triplex that the POCO installed.
Usually, the electrician gets blamed for the lights dimming, even if we can prove the problem is on the POCO side of the service. Most annoying!
Rob
micromind is offline   Reply With Quote
Old 11-17-2008, 11:20 PM   #4
Electrician
Rob
POCO's due not have the same rules as electricians that have to follow the NEC. IMO, they can run 250's and the lights are still going to dim. AC units simply just have to much starting current.
chris75 is offline   Reply With Quote
Old 11-17-2008, 11:34 PM   #5
Idiot Emeritus
A POCO engineer once told me, in complete honesty, that they size their equipment (transformers, wire, etc.) based on what survived and what didn't.
The statement I remember most is 'If you don't burn up a transformer every now and again, you're oversizing them".
If you look at some of the stuff they get away with, the above is likely true!
Rob
Old 11-17-2008, 11:38 PM   #6
Electrician
Rob
IMO, the NEC service requirements are simply crazy, and the POCO's know what real loads are, plain and simple. but I do agree with your engineer's idea.
Old 11-18-2008, 12:26 AM   #7
I have started to isolate the AC breakers (AZ) because they will sometimes get hot, burn the bus and affect breakers around them.
220/221 is offline   Reply With Quote
Old 11-18-2008, 08:19 AM   #8
ACs need bigger caps....
rgsgww is offline   Reply With Quote
Old 11-18-2008, 11:35 AM   #9
Interesting.
Caps give a jump start right?
Less jump start from a cap means more amp draw at start, right?
Hmmmm.
How would someone find out the proper cap size?
How would someone read the cap size?
How would someone test the cap?
Is a hard start kit simply a bigger cap???
Old 11-18-2008, 11:58 AM   #10
Yes, I just meant they need to make them with bigger caps...
Old 11-18-2008, 01:47 PM   #11
Rewards Points: 506
Send a message via AIM to theatretch85
Smaller caps = less cost to the consumer (upfront anyway). Big appliances with a large startup current (mainly those with large motors) should have larger caps to help with the startup of the appliance.
Edit: I wouldn't reccomend anyone to be messing around with large capcitors on their household appliances for the simple fact that they can store a lot of energy even when the power is off to the appliance.
theatretch85 is offline   Reply With Quote
Old 11-18-2008, 02:47 PM   #12
Oh yeah, I would never mess with those caps. I think they should...its less wear on the cbs and connections anyways. (most cbs shouldn't have a problem.)
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
