Panel Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2010, 09:20 AM   #1
Smile
Panel issues
Okay so trying to wire a breaker for my dryer. The landlord gave me a 30a breaker for the dryer but i only got 3 slots open and the breaker takes up four. as this is not my house i dont want to start investing in adding a sub panel. Is there anything else i can do? Can I put the bigger breaker in where the stove is and come off the outlet for the stove? Is that even safe if i dont use both of them at the same time?
jason30 is offline   Reply With Quote
Old 04-21-2010, 09:33 AM   #2
Electrician 30 yrs +
I can assume that the type of breaker you have is GE? They are the only brand i can think of that makes thin breakers.GE makes a thin twin 2 pole 30 that should fit in 2 of the 3 spaces u have left. You probably have to go to a supply house to get it though,find a supply house that sells GE.
No do not double up on the stove breaker not acceptable!!
Hope this helps.
Huck
huck is offline   Reply With Quote
Old 04-21-2010, 11:16 AM   #3
You are doing the work on rental property that you do not own ?
I hope you have something in writing from the landlord
Against code to 2x up & unsafe to do so
Old 04-21-2010, 11:18 AM   #4
Rewards Points: 160
The landlord gave you the wrong breaker. Your landlord should be doing this work not you.
Old 04-21-2010, 11:31 AM   #5
Electrician
Rewards Points: 794
I agree take the breaker back to the landlord and tell them to do it themselves. Thats the only thing i miss about my apartment is that when something broke i could call the landlord and it would get fixed, now i have to fix it myself.
darren is offline   Reply With Quote
Old 04-21-2010, 11:46 AM   #6
Just call me Andrew
Rewards Points: 1,020
Andrew
secutanudu is offline   Reply With Quote
Old 04-21-2010, 12:19 PM   #7
Exclamation
update
okay so when we moved in there is only 1 220v outlet for the stove. The landlord said he wont put another in for the dryer cuz there is gas hook ups for the dryer. He said he would get me the breaker to add another but he wouldnt pay to have it done. He gave me a 2 pole 30 breaker. So It wont fit in the sub panel but will in the main disconnect. Is there any harm in putting it there? The panels are federal pacific 100 amp 120/240v ac 1 phase 3 wire.
So what it comes down to is it if i cant install the 220 outlet im screwed and would have to purchase a gas dryer to use here.
Old 04-21-2010, 01:40 PM   #8
Well that changes everything
You couldn't pay me to touch a Fed Pacific panel
Too many problems with them:
http://www.inspectapedia.com/fpe/fpepanel.htm
Old 04-21-2010, 04:15 PM   #9
Electrician
Rewards Points: 794
Why not sell your current dryer and buy a gas one and go with what they have.
If i was a tentant of an apartment, i would not touch anything electrical. As soon as there is a problem they will comeing hunting for you and blame it on you.
Tags
electical wiring , electric wiring problems , electrical box , electrical question
Drywalling around an existing panel... any code issues? tigereye Electrical 2 12-29-2009 11:10 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
