Panel Info - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 10:36 PM   #1
Rewards Points: 528
panel info
When labeling panel breaker numbers can u use the inexpensive, magnetic ,stick on tape on back of #s ( mine are laminated)
beside breaker ,or is that type material forbidden because of magnetic energy?
hidden1 is offline   Reply With Quote
Old 10-05-2013, 10:39 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by hidden1 View Post
When labeling panel breaker numbers can u use...
...anything you might have handy? Pretty much.
Old 10-05-2013, 11:23 PM   #3
Rewards Points: 6,652
Spreadsheet is easier. You just enter the info in, then print it out and place in a sleeve. I always like it, when people will use a sharpie on the Dead front, to label the breakers or fuses.
Old 10-06-2013, 12:09 AM   #4
dmxtothemax's Avatar
Rewards Points: 5,598
I don't think that any magnetic type of label could have enough magnetism
to interfere with the operation of a breaker or gfci
How ever codes are seldom based on reality,
So I' am not sure what they say !
dmxtothemax is offline   Reply With Quote
Old 10-06-2013, 02:05 AM   #5
More like codes are not built on the common human perspective, when it comes to being analytically thinking outside the box.
The problem with the magnetic labels, is that they would be easily moved, or some inspector would state that they are a shock hazard, because they contain metallic particles in them, and could possibly fall off into the shell, when the Dead front is removed.
Remember the only hazard when working around electricity, are those who think that they know more about the book, then those who wrote the book. I do not even trust those that work on these things all the time, because most times their mind is elsewhere, and not 100% on the task.
Old 10-08-2013, 08:52 PM   #6
Rewards Points: 528
Thanks ,i guess i will have to use something more permanent to hold the laminated numbers in place.
i have some flat double sided tape i can use or i can just put clear tape over em..just want it to look good for later if inspected.Has a laminated chart inside door identifying breakers.
Old 10-09-2013, 10:05 AM   #7
MarginallyQualified
Thanks ,i guess i will have to use something more permanent...
http://www.markal.com/liquid-paint-markers/
If you insist on spending money:
http://www.seton.com/best/engraved-e...l-panel-labels
Old 10-09-2013, 02:39 PM   #8
seansy59's Avatar
Rewards Points: 258
I used Microsoft word and made a small chart for the amount of row of breakers. Set the inches correct (1in for full breakers, 1/2" for tandems. And labeled them like that. Especially easy to read for others...and I also labeled circuit numbers on the panel, and on the devices/recepticle themselves.
seansy59 is offline   Reply With Quote
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
