Panel History (old Breaker Panel Question)
Why couldn't your electrician tell if the ground was bonded? It is a matter of locating the bonding jumper, either strap or screw, that connects the neutral with the panel enclosure. And as you did, a continuity test between the two.
I don't know, I wasn't talking to the guy. My dad was impressed with the guy, but them my dad told me what he said about not knowing if it was bonded or not. Then the electrician told me dad that if it wasn't bonded that's probably why all the damage occurred.
I think it is bonded under the main breaker, and he probably didn't want to pull the main. But I don't know why he could not have used a meter.
My pushmatic panel from 1963, which would have been install around the same time as my dads CH panel, appears to be permanently bonded to the box with no isolation.
As far as grabbing a current carrying neutral, well, it depends on the voltage drop on that neutral. If the neutral is heavily loaded and you have a large voltage drop, then a current could flow from it to ground, but it would be small. A matter of a couple of volts won't even be noticeable to a person. Any more than that and you likely have a bad neutral connection.
This guy (electrician without a meter) had no way of knowing what the load was or if the neutral was bad. I wonder why this guy didn't exercise a bit more care...
Now with a clamp meter, I should see the difference in the unbalanced load, just like I would see on a MWBC, right?
Jamie
Jamie Dolan - Neenah, WI
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Need Help Uploading Photos? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
