Panel Grounding Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 08:10 PM   #1
Panel Grounding requirements
I am rewiring my house and changing the panel 100Amp panel. can I clamp the water pipe grounding wire to the grounding rod wire before it goes into the panel or do these both have to have their own screw in the panel.
Thanks in advance for any help or reply's
POWER STROKE is offline   Reply With Quote
Old 08-26-2012, 08:19 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
They both have to be continuous from the panel to the first rod/within 5' of entrance of water.
Old 08-26-2012, 08:31 PM   #3
Thanks for your help
Old 08-27-2012, 06:46 PM   #4
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 11:49 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Electrical Sub Panel Grounding KellyElaine Electrical 17 01-17-2011 07:46 PM
sub panel grounding jprince Electrical 2 05-04-2009 07:15 PM
