Old 08-04-2008, 02:08 PM   #1
Joe F's Avatar
Panel ground questions
I recently did some plumbing work and needed to lengthen the ground wire that goes to the copper plumbing main. The existing ground is 4ga and I added 3 feet of 6ga spliced in with 2 bugs. Do I need to swap it out with a piece of #4 or am I OK as is?
While I was doing this work I started thinking . Aren't the neutral and ground the same where they attach to the earth ground (copper pipe or driven ground)? If they are the same, why isn't there current in the ground wire? or is there? I couldn't figure this out when I was doing the work so I killed the main until I had the ground re-bonded to the plumbing line.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 08-04-2008, 04:17 PM   #2
Electrician
If your copper pipe is a GEC (grounding electrode conductor) then you cant splice it, back to the drawing board.
Because the current wants to get back to the transformer on the street not to the earth. Ground rods and using the metal piping as a grounding electrode are only for lightning, surges, unintentional contact with higher-voltage lines.
chris75 is offline   Reply With Quote
Old 08-04-2008, 04:30 PM   #3
Joe F's Avatar
OK. I'll run a new ground wire back to the panel. What size wire do I need for a 200 amp service?
Old 08-04-2008, 04:31 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Turning the main off will not remove dangerous amperage on the grounding conductors if it is coming from an external source due to a fault on the utilities grid such as a neighbors service lateral. treating the grounding conductor like any other is a good idea never assume it is safe to handle before testing for current flow. There are many plumbers who will attest to the current flow in metal drain pipes....from external faults outside the home....
Old 08-04-2008, 06:13 PM   #5
Electrician
Its actually based on the size of the service entrance conductors, but most likely #4 cu. is good.
Old 08-04-2008, 06:14 PM   #6
Electrician
And here is a great article to explain all about it... http://ecmweb.com/grounding/electric...uth_grounding/
Old 08-04-2008, 06:49 PM   #7
It was a dark and stormy
Yoyizit's Avatar
"Because the current wants to get back to the transformer on the street not to the earth."
This may have already been said or implied, but the voltage to ground of an ungrounded xformer secondary is indeterminate.
Because of interwinding parasitic capacitance, the secondary voltage may float up to the primary voltage, or it may not because winding capacitance to ground may overwhelm the other capacitances.
Grounding the center tap somewhere makes the secondary voltage with respect to ground predictable and independent of stray capacitance; that is, a max of 150vrms.
Mr. 75, there is more to that article than meets the eye. It may save lives.
Old 08-04-2008, 08:21 PM   #8
Electrician
As long as it makes sense to you....
Old 08-04-2008, 08:26 PM   #9
Yoyizit's Avatar
There I go again!
Old 08-04-2008, 09:36 PM   #10
Licensed Electrician
jrclen's Avatar
#4 copper with no splices.
John
jrclen is offline   Reply With Quote
Old 08-05-2008, 09:47 AM   #11
Joe F's Avatar
Thanks.
For a minute there I thought I was going to have to change all the DiLithium crystals.
Old 08-05-2008, 10:17 AM   #12
Yoyizit's Avatar
Thanks.
After any encounters with The Borg it is recommended to routinely change all the crystals.
And check your anti-matter pods.
Old 08-05-2008, 10:48 AM   #13
jrclen's Avatar
Thanks.
LOL. Sometimes we forget there is an OP (original poster) waiting for an answer.
John
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 11:17 AM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
