Panel Fault -Unknown Cause - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 10:26 AM   #1
Second time this occurred, two weeks apart. This is an account of the second time, because I was more careful to slowly troubleshoot:
The power was out to half of the home, and upon inspection to the panel, none of the breakers had flipped. I flipped the suspect breakers one by one to be sure, on each circuit that was out and nothing happened.
Then, I flipped a circuit that had power to OFF, and the four OUT circuits turned on. I flipped the unrelated circuit back on, and all is well.
First time this happened I just flipped circuits to exercise the breakers, with the same result.
Main looks good, especially because the OUT circuits were on both sides of the panel. Could this be solar flares ? OK, seriously, what is this?
jkbadge is offline   Reply With Quote
Old 03-09-2012, 10:40 AM   #2
>intermittent failures
>split bus panel?
>internal breaker contacts failed anyway?
>intermittent connection or bad neutral
>there are changes happening in this circuitry that you may not be causing.
In general, ask yourself:
What must be true for this to be happening?
and
What am I assuming is true that is not true?
With a two week return period, knowing with any certainty that any fix anyone tries has actually worked will be pretty time consuming. It's a 6 week no-fault wait for 95% certainty and a four week wait will give you 86% certainty. I would find a reliable way to induce the fault.
Old 03-09-2012, 10:46 AM   #3
Rewards Points: 3,256
One side of your main breaker has become intermittent or there is a connection problem somewhere between the utility transformer and one of the bus's in your panel.
Each bus alternates on both sides of you panel so that is why all of the breakers on one side are not effected as you mentioned.
zappa is offline   Reply With Quote
Old 03-09-2012, 10:55 AM   #4
Originally Posted by zappa View Post
One side of your main breaker has become intermittent or there is a connection problem somewhere between the utility transformer and one of the buss's in your panel.
This would be my guess. Is the main breaker hot?
JRigby is offline   Reply With Quote
Old 03-09-2012, 11:05 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
deleted.
Old 03-09-2012, 11:16 AM   #6
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You will need a meter to check the voltage to see if it's on your end or not. If you are not comfortable doing any of this please get help.
If you don't have 240 before your main breaker it could be anywhere between your main panel and your service drop from the pole or underground lines.
If there is 240 between both hot legs in the panel before the main breaker and not after the breaker you have a main breaker problem.
If you have 240 before and after your main then there could be a bad connection between the bus bar and your main breaker.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 12:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
