Panel Cover Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 10:38 AM   #1
Panel Cover needed
I recently purchased a property in which the electrical cover panel is missing. the load center is a Cutler Hammer: CH30JJM150, which calls for either a CH7JJS or CH7JJF cover panel. Apparently these model cover panels are discontinued. I have found a replacement panel thru Platt, but at $240 I'm hoping for a better solution. After all, it's just a panel cover. Help!
mgimenez is offline   Reply With Quote
Old 06-06-2013, 12:28 PM   #2
joed's Avatar
Rewards Points: 13,722
The better solution might be a new panel.
Old 06-06-2013, 09:33 PM   #3
Rewards Points: 446
A long shot might be to call around to your local electrical contractors and explain what you're looking for. They might have one they'll sell you from one they've replaced.... or at least let them know what you're looking for. Might be a lot cheaper than what the new one is you found.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
mgimenez (06-07-2013)
What Went Wrong? Breaker Panel Swap (expert advice needed!) swfl Electrical 53 12-23-2012 12:20 PM
Are lug's code compliant on this DIY 175A breaker panel? Needed for 10KW PV system superduper Electrical 23 09-09-2012 12:13 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Help need circuit panel box cover kathykobzina Electrical 4 11-19-2010 04:51 PM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
