#1 |
I ask the impossible!
Panel clearance requirements & workbench construction
So the picture below shows the wall where I have installed outlets in my detatched garage workshop with the new 100A panel I have installed shown on the left. I intend to build a workbench, I wanted to see if someone could clarify if I would require 30" or 36" or otherwise of depth for clearance to the panel? And since the panel is surface mounted, that distance is from the panel cover?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner. |
#2 |
Electrical Contractor
You will need a 30 inch wide space, extending out 36 inches from that panel to be Code-compliant for working space clearances.
The 30 inch wide space must include the entire width of the panel, but can extend beyond either or both sides of it. That being said, the pegboard could remain, even with tools hanging on it, but the workbench itself should be located far enough away to allow for the required working clearances.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to kbsparky For This Useful Post: | electures (06-27-2011) |
| Display Modes | |
| Wiring a sub panel to another sub panel | Uncle Wayne | Electrical | 25 | 02-08-2011 10:50 AM |
| Panel Swap | Old College Try | Electrical | 37 | 06-07-2010 09:37 PM |
| This doesnt seem right. | JoulesWinfield | Electrical | 27 | 07-26-2009 08:40 PM |
| Garage Wiring issues | jimmyfloyd | Electrical | 20 | 06-08-2009 03:57 PM |
| Panel Placement In Outbuilding | smitty286 | Electrical | 3 | 03-31-2008 01:20 PM |
