Panel Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 05:07 PM   #1
panel breaker question
Right now I have a sub panel and it has 2 20amp single pole breakers that are being used for other things ( 1 a 220 volt plug and 1 for a heater ). Those 2 aren't being used and I want to install baseboards in my bedroom.
My question is: Can I remove those 2 single pole breakers and install a 20amp double pole breaker??
I want to install 2 baseboards on 1 thermostat.
Would this work??
officersdr is offline   Reply With Quote
Old 09-18-2010, 05:22 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it depends what the load of the heaters is. The thermostat also must be able to handle the load of both heaters as well.
as to the current situation; you should have had a 2 pole breaker there already.
so, what size are the heaters?
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 12:28 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Main Breaker panel question stagger19 Electrical 5 08-15-2006 04:57 PM
