Old 10-29-2012, 02:19 PM   #1
panel box/rewire
Does this look like it needs to be re wired ?It is a 70s box with mostly old wiring
panel box/rewire-imag0114-1-.jpg.panel box/rewire-imag0116.jpg
hidden1 is online now   Reply With Quote
Old 10-29-2012, 02:42 PM   #2
DIY Enthusiast
sublime2's Avatar
panel box/rewire
Nope.
Looks pretty clean.
sublime2 is offline   Reply With Quote
Old 10-29-2012, 02:50 PM   #3
Julius793's Avatar
panel box/rewire
Looks fine the only thing I noticed is the neutral right side by the bottom looks a little funny, can't really tell what it is.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 10-29-2012, 03:52 PM   #4
Lic Electrical Inspector
electures's Avatar
panel box/rewire
Looks good in the pics.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 10-29-2012, 03:55 PM   #5
Master Electrician
panel box/rewire
Is it a main panel or a subpanel. Don't see a bonding screw or jumper.
brric is offline   Reply With Quote
Old 10-29-2012, 07:47 PM   #6
panel box/rewire
That may be the curly GFI wire.Its the main panel.Has a neutral row with 4 silver wiring also,copper with it side by side(seperately) panel box/rewire-imag0113.jpg
Old 10-29-2012, 08:16 PM   #7
Master Electrician
panel box/rewire
Originally Posted by hidden1 View Post
That may be the curly GFI wire.Its the main panel.Has a neutral row with 4 silver wiring also,copper with it side by side(seperately) Attachment 59662
That is the GFCI neutral.
Old 10-31-2012, 05:42 PM   #8
panel box/rewire
Got it re wired .Used a tandom 20 amp in place of the old 50 .replaced that old #6 crap with the #12 copper.Is on its own outlet for over range microwave.Can the-GAS-stove be plugged in to that outlet also?It doesnt pull much.
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
