Pancake Box Help - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 11:13 PM   #1
Pancake Box Help
Hi all,
Newbie beginner question (no laughter pls!)...Using pancake boxes for the first time as I came across a stud (3/4 inch from drywall) when moving a light receptacle to it's new location. As it's not plastic, I understand I need a 'connector' to attach the romex to the metal box? How do you then get the pancake box flush to the stud (and your drywall for that matter), with the connector sticking out back? Also I'm not use to the clamps on the pancake box, can someone explain how or what I'm fastening to that?
Thanks in advance
bigsky21 is offline   Reply With Quote
Old 09-18-2013, 11:55 PM   #2
Rewards Points: 14,026
Got a picture of what your talking about?
Any connectors should be in the top or bottom of the box not out the back in most cases.
Sure your using the right connectors?
http://www.bing.com/images/search?q=...lectedIndex=10
Old 09-19-2013, 04:43 AM   #3
Licensed electrician
Rewards Points: 1,788
Normally the box can be rotated so that at least one of the knockout is not over the stud. You do not need to use the center hole.
As far as the connector, it depends on the style you are using. If it has a locknut, the locknut goes on the inside of the box.
Old 09-19-2013, 05:09 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Use one of these:
http://www.homedepot.com/p/Westingho...4#.UjrNRn82hSN
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-19-2013, 06:03 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
4" pancake boxes can be a real pain in the ass when it comes to box fill, I generally just use a 4" hole saw and install a 4" octagon 1.5" deep box....
porter cable pancake compressor issue. Need some help bfan781 Tools 5 06-27-2011 10:06 AM
Tips on installing pancake box in brick humberguy Electrical 2 10-08-2010 03:23 PM
Pancake sandwich shumakerscott Off Topic 2 05-27-2010 08:52 AM
Pancake, I'm on a food kick! shumakerscott Off Topic 0 08-31-2009 12:12 PM
Advice on purchase of a pancake compressor joe3534 Building & Construction 18 04-14-2007 04:03 PM
