Painting Or Replacing Canister Ceiling Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 10:54 PM   #1
Painting or Replacing Canister Ceiling Lights
I have existing recessed canister lights in my ceiling. Is it possible to paint recessed canister ceiling lights that are black in the recessed portion, surrounding the bulb. I would prefer them to be white since the ceiling is white. Can they be painted and if so, what kind of paint? If not, is the only option to have them replaced and can that be done without tearing apart the ceiling? Finally, is there some advantage to having black rather than white in the recessed portion of the fixture? Thank you.
justagirl is offline   Reply With Quote
Old 07-14-2008, 03:38 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Most of the recessed cans do have removeable trim so you can change the trim if need to.
Some are removed by spring clip and some are removed by unscrewing and some are removed by two screws.
The black interal trim is used to keep the glare reflection reduced.
Yes you can get white trim ring both do come in white or black sleeve depending on the type of bulb you use and how far back it set.
Merci,Marc
Tags
painting
popcorn ceiling painting phil334 Painting 2 07-11-2008 11:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Why are ceiling lights not central? captslogg Electrical 12 11-28-2007 11:30 AM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
