Oxidation On Wires To Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 10:30 AM   #1
Oxidation on wires to light switch
While changing a light switch I discovered that a pair of wires (red and black), which were threaded together and secured with a merret had some oxidation when I removed the merret, which also has signs of rust.
Also, some of the wire sheathing, which was threaded also, was melted.
I removed as much of the sheating, filed off the petina, replaced the worn merret, and secured it all with electrical tape.
Is there anything I should be concerned about? I can post a picture if it nakes it easier.
Thanks in advance!
earthad1 is offline   Reply With Quote
Old 10-23-2010, 10:49 PM   #2
Rewards Points: 1,514
You have to get all the patina (oxidation, rust) off namely get the wire end bright and shiny. If the wire end was wrinkled by the merret (marette, wire nut), it may be so hard to get the patina off that you have to cut off the exposed end and trim off more sheathing (insulation) to get a new bare wire end.
Suggest very fine sandpaper (or crocus cloth) to get the patina off.
The plastic sheathing was melted because the patina introduces resistance into the circuit at that point and resistance results in heat.
If the sheathing was threaded, there is a good chance the marette hung up on the sheathing and never fastened the wires themselves tightly and a loose connection often gets hot.
Old 10-26-2010, 08:51 AM   #3
Thanks for the help... Did exactly what you suggested... I did have to cut a bit off both ends .
Thanks again.
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
two hot wires to light switch? magnolia Electrical 2 05-10-2008 03:53 PM
