Overvoltage Best Way To Reduce-buck-or? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2014, 07:20 PM   #1
overvoltage best way to reduce-buck-or?
I have a house in Costa Rica that is supplied by power company with 60 cycle measured voltage of 242-244 but can go as high as 252 volts (5%).
I have 5 installed mini split airconditioners that are only rated for single phase 220-230 volts. they are protected by surge suppressors but I need to reduce the voltage either at the box or at each individual unit. They have sensitive computer boards in them that are known to fry with 240 volts. I am looking for the best way to do this. It is a problem for all houses in the area that use similar a/c units, but power company will not lower voltage without unanimous consent.
I will have an electrician do the work but would like opinions on how to go about this efficiently and cost effective. Buck Boost transformer at box or individual units or some other method? Install a separate box just for the a/c units? There are no other 220 or 230 rated appliances in the house.
Help and thanks.
jake111 is offline   Reply With Quote
Old 03-22-2014, 09:05 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,922
I'd say individual buck/boost transformers would be the easiest solution. The alternative might be a subpanel fed from one buck/boost transformer, but that seems more difficult and probably more expensive.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 03-23-2014, 12:26 AM   #3
dmxtothemax's Avatar
Rewards Points: 5,174
Yes I concurr !
A bucking transformer is probably the easest option !
But make sure it's done properly ! prefered by an electrician,
Who is familuir with the local electrical codes !
dmxtothemax is online now   Reply With Quote
Old 03-23-2014, 06:13 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You can do the buck boost transformer, but remember, if the power company does lower the voltage in the future, you could be under voltage at the AC units, but very unlikely. But just a thought.
Old 03-23-2014, 07:11 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Most of those ratings have a tolerance of +/- 10%, check with the manufacturer, because you should be fine.
Old 03-23-2014, 08:15 AM   #6
E2 Electrician
I know every tanning bed I've ever done with a 208v service required a buck boost transformer, and almost every manufacture required this.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (03-23-2014)
Old 03-23-2014, 08:18 AM   #7
k_buz's Avatar
Never wired up a tanning bed, but I have wired many CNC machines rated for 220V 3P on 240V 3P as per the manufacturer.
Removing metal window buck Vk60564 Windows and Doors 7 08-04-2013 07:30 AM
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 12:06 PM
Should I add 2 rotary turbine vents to roof to reduce summer heat? pcumming Roofing/Siding 3 09-30-2011 08:26 AM
Need to reduce humidity in house creamaster HVAC 4 11-19-2008 04:03 AM
Does Drylock waterproofing help reduce radon? nuadhu1 Remodeling 1 02-10-2008 06:47 AM
