Oversized Switch - Why? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 04:02 PM   #1
Oversized switch - Why?
I live in a two story house. My furnace and electrical box is in the basement. In the main hall on my top floor is a switch for the primary exhaust fan. It is in the same box as an actual light switch. The switch for the exhaust fan looks like a regular light switch except that it is bigger. As we paint the house, we have been changing all of the switches from the older style switches to the new rocker style switches. Any idea why this switch is different? Can it be replaced with a normal switch? I have taken the cover plate off and the connections on the actual switch look the same as the 4 way switch that is beside it. I haven't actually pulled it apart yet, so I am not sure how many wires are running to it or what colours they are. What do you think?
DirtSquirt is offline   Reply With Quote
Old 11-06-2008, 04:30 PM   #2
Rewards Points: 2,350
It is either a motor-rated switch or a "spec" grade switch. It is likely a 20 A switch, because of the larger starting load of the motor.
Old 11-07-2008, 04:57 PM   #3
DIYer
Big inductive loads cause arcing on switch contacts. I would not replace it solely for cosmetic value with a switch that might not be rated for that use.
Gigs is offline   Reply With Quote
Old 11-08-2008, 11:53 PM   #4
Rewards Points: 508
Send a message via AIM to theatretch85
If it looks like a 4 way switch its probably a heavy duty double pole switch, intended to switch 2 independent circuits (in the case of a 240 volt device). I'd the wiring, see how many wires are connected and how, then check voltage to each set of wires (determine if its 120 or 240 volts).
theatretch85 is offline   Reply With Quote
Old 11-09-2008, 12:57 AM   #5
You need to use the right switch. Look at the text on the switch, what does it say?
If you go with a normal switch, you might just hear a loud pop every once and awhile and feel it getting hot....
rgsgww is offline   Reply With Quote
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
