Are Oversized Romex Staples Against Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 06:05 PM   #1
Are oversized romex staples against code?
It looks like the staples I bought are of different sizes and the bigger ones aren't as snug on 14 gauge wire but is this against code?
Drliebs is offline   Reply With Quote
Old 07-26-2011, 06:35 PM   #2
Rewards Points: 6,652
What does the box/packaging state for cable size. When you use staples, they only need to be in far enough that it keeps the cable from hanging loose against the stud. More so for securing the romex, so that the drywallers do not pinch a loose cable when hanging the drywall, and also to secure at the junction box to keep the cable from being pulled out of the box.
Old 07-26-2011, 07:10 PM   #3
The package says:
3/4 " Plastic Insulated Staple
10/3 12/3 14/3
Seems like a silly question I guess...I suppose a 10/3 is a lot wider than 14/2 and that is where the extra width comes in? I just saw 3/4" and grabbed them thinking I would have enough nail for stacking 2 cables.
Old 07-26-2011, 08:09 PM   #4
Those will work fine. Just use them up. As for stacking, they actually make special plastic clips for doing that.
Running romex through groove cut in 4x4 sealed with 2x4? Code legal? vacatari Electrical 9 10-16-2010 01:58 PM
Exposed wiring - would this be Code? globus999 Electrical 3 09-14-2010 06:07 PM
sharing an outlet box for a splice - code? drgkjd Electrical 6 08-04-2010 12:09 PM
Need advice; GC's ignorance of code to cost us extra? Merst Off Topic 9 06-12-2010 09:22 AM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
