Oversized Electrical Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 02:31 PM   #1
Oversized electrical wire
I got rid of my spa and i am leftwith a 8/3 wire outside. The wire is connected to a 50 amp breaker in my main panel in the house. I want to use the wire to run lights to a gazebo. Can i use the 8/3 wire or do i have to pull the 50 feet of 8/3 out and replace it with a 14/2 wire? Can i leave the 50 amp breaker in and keep the 8/3 wire connecting it to a new out side 4breaker panel to runthe lights from?
Benjiboy is offline   Reply With Quote
Old 04-21-2013, 03:07 PM   #2
joed's Avatar
Rewards Points: 13,730
You can use 8/3 but not the 50 amp breaker.
Good option but you need a 15 amp breaker in the new panel.
The Following User Says Thank You to joed For This Useful Post:
Benjiboy (04-21-2013)
How to mend underground sprinkler electrical wire diyatx Electrical 1 02-28-2013 01:47 AM
Fishing PEX through walls like electrical wire? Pele2048 Plumbing 1 02-20-2013 05:01 PM
Where do you source your residential electrical wire? diystephen Electrical 9 11-25-2012 10:40 AM
Electrical wire size question. shawnlee Electrical 11 08-11-2009 06:25 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
