Override Garage Door Electronic Eye - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:05 AM   #1
Override garage door electronic eye
Ones anyone have any ideas on how to override the electronic eye system on a craftsman garage door opener. I want to use one for a trolley to access the back of my loft. Have no way of setting it up with the eyes and I also don't have an extra set of eyes
robs660 is offline   Reply With Quote
Old 04-21-2012, 10:09 AM   #2
I=E/R
a7ecorsair's Avatar
One way is to mount the eyes above the torsion spring.
Never mind, I see you aren't using it to open a door....
a7ecorsair is offline   Reply With Quote
Old 04-21-2012, 10:26 AM   #3
Rewards Points: 150
I would not rob the eye sensors from the safety system on a garage door. The infrared eye kits are not that expensive.
Jeeps is offline   Reply With Quote
Old 04-21-2012, 10:49 AM   #4
I know I can buy new eyes. I want to install without them. I have a large loft and I have always dreamed of building a train to shuttle stuff from back to front
Old 04-21-2012, 11:01 AM   #5
I=E/R
a7ecorsair's Avatar
Are you saying you don't have safety eyes? In you opening post you used "an extra set of eyes" which I understood as you have one set that came with the opener. Is this a removed or used opener?
Old 04-21-2012, 11:04 AM   #6
Rewards Points: 150
Sorry if my reply was not on target but your opening question appears to state that you want to overide or remove a eye from your garage door opener. So you want to use a GD opener on your train set up ? If it will be safe for the application, just jumper the terminals on the GD control board that the infra red eyes hook to.
Old 04-21-2012, 11:08 AM   #7
Rewards Points: 6,652
Everyone you have missed the point of the OP. They are not using the opener for a garage door. What they are using the opener for, is to move stuff back and forth across a area. They are wanting to know how to use the device but not install the eyes in the system.
Old 04-21-2012, 11:28 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I do not believe jumpering the terminals will work. Connect the eyes and tape then together facing each other.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
gregzoll (04-21-2012), k_buz (04-21-2012)
Old 04-21-2012, 11:28 AM   #9
I=E/R
a7ecorsair's Avatar
greg, see post two.
OP: I'm guessing the Craftsman opener is really a Chamberlin. These are designed to prevent cheating the safety system so I don't believe you can just jumper the pins in the motor head.
Old 04-21-2012, 12:17 PM   #10
Rewards Points: 150
I have never tried it but I would think you are correct. I stand corrected.
Old 04-21-2012, 02:49 PM   #11
Taping the eyes together will work.
I believe there is a certain amount of resistance that the photoeyes have so jumping is out. If you do some web searching you may be able to find the correct resistance and use a resistor between the black/white terminals.
Most units will run in constant pressure (holding the button continuously) till it hits the close limit.
Doorman54 is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
