Overloading A Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2015, 01:34 AM   #1
Rewards Points: 119
Overloading a Socket
I was wanting to add some more florescent lighting to my garage. I currently just have a standard 2 socket in the ceiling connected to a switch. It has (2) 2 bulb fixtures and a single 4 bulb fixture. Would it be safe to add 2 more 2 bulb fixtures? Thanks for any help.
Also another question didn't want to create 2 threads since they are related. On the side of my house i have a sliding door with a floodlight with a switch on it. Down the walkway there's a exterior door. Can i tap into the floodlight and add a light to the exterior door. Thanks.
texasman21 is offline   Reply With Quote
Old 03-15-2015, 02:20 AM   #2
Rewards Points: 299
Are you saying you have these plugged into a standard duplex receptacle? If so, you can have 15 or 20 amps on those, depending on breaker and wire size, without "overloading" anything. You are not even close.
Syberia is offline   Reply With Quote
Old 03-15-2015, 02:23 AM   #3
Rewards Points: 119
I think its a 20 amp breaker. Also on that breaker is a fridge and freezer and garage door opener. Am i still safe?
Old 03-15-2015, 02:38 AM   #4
Rewards Points: 299
The maximum wattage allowed on a 20 amp circuit is 2400 watts, or 1920 watts continuous. Assuming you have 32 watt T8 bulbs, that's 256 watts of lighting currently plugged in. You're adding 4 more bulbs, or 128 watts, for a total of 384. Your fridge and freezer probably use a couple hundred each, perhaps less, when running. The GDO also should not pull too much power, and is extremely intermittent. You will be fine.
Incorrect UK Socket Wiring On US Transformer JasonCA Electrical 9 09-21-2014 05:12 PM
Socket Meter Box, Circuit Breaker Panel and Beyond tk3000 Electrical 37 04-21-2014 11:55 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Light cord to screw in socket adapter? Charger Electrical 11 05-02-2010 06:04 PM
