Overloaded Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2008, 08:54 PM   #1
DIY Expert in Training!
Overloaded circuit?
I have some experience with electrical work but don't know about circuit loads. We are thinking about changing 2 rooms from switches powering outlets to ceiling fans. Here is what the current situation is:
20 amp circuit
10 outlets across 3 bedrooms and an outside light.
Thoughts?
gone_fishing is offline   Reply With Quote
Old 06-24-2008, 09:37 PM   #2
You should be fine adding two ceiling fans to that 20A circuit.
Super33 is offline   Reply With Quote
Old 06-25-2008, 10:49 AM   #3
Really? How do I calculate the current load? I do have a TV, LCD TV, Stereo, Computer, lights, etc on there now.
Old 06-25-2008, 11:58 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Add all the wattages from the different devices you have and subtract that from 2400, that tells you how much capacity you have left.
P=I*E
P=power in watts
I=amps
E=voltage
Old 06-25-2008, 05:41 PM   #5
Do you have any electrical testers? If you happen to have an amprobe you can take off your panel cover, turn on your stuff on that circuit and go back to your panel and check the amperage running through that #12 wire coming from that 20A breaker. A standard ceiling fan draws between 10 and 100 watts with no light kit, that's less then 1 amp. 2 60 watt bulbs draws approx. 1 amp. 4 40 watt bulbs draws approx. 1 amp. You want to try and stay below around 16 or 17 amps tops.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
