Old 01-06-2010, 11:51 PM   #1
overload circuit with heat lamps?
I need to plug in two 250watt heat lamps into two GFCI outlets which may be wired together. I'm not sure what else might be on the same breaker but the lamps would probably be used only for a couple nights so the other loads would be minimal. Any idea how much current these things draw? I'm a little concerned as I plan to leave them on while I sleep.
higgins is offline   Reply With Quote
Old 01-07-2010, 12:08 AM   #2
250 watts divided by 120 volts =2.08 amps each.
hayewe farm is offline   Reply With Quote
Old 01-07-2010, 06:59 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Originally Posted by Martina09 View Post
To remove a plug fuse, grasp it by the rim and turn counterclockwise. To be on the safe side, use only one hand, keep the other hand in your pocket (in this way you avoid making a ground contact). Make sure that you stand on a dry surface. As an extra safety precaution, you can keep a board (a 16-inch length of 2-by-6 is ideal) on the floor by the panel. Standing on this will provide additional insulation when you replace fuses.
???? Wrong thread I assume?
Old 01-07-2010, 08:24 AM   #4
Xtreme DIY'r
It was someone who said they were from Canada
But they were actually a spammer from India
Buh bye
Old 01-07-2010, 09:16 AM   #5
Inspector/Instructor
codeone's Avatar
Good one Dave I like
codeone is offline   Reply With Quote
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 06:26 PM
saltwater tank circuit overload pamelajo Electrical 5 06-02-2009 01:14 AM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat lamps Bob Bala Electrical 3 09-26-2007 06:37 PM
