Overkill? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 03:56 PM   #1
Overkill?
I struck up a conversation with a fellow at Home Depot yesterday.
He was telling about a municipal requirement for grounding that I'd never heard before. He said they required a 4ft. hole cubed in the ground with 25 ' of bare #4 coiled around the edges of the hole with this bonded to the panel. He didn't indicate if any electrodes other than the #4 conductor were used.
I had been told in another forum that a good way to ground a panel was to completely surround a structure (a home for example) with a #4 conductor buried at a depth of 2 feet with multiple electrodes set at intervals along this path.
1. Isn't this overkill?
2. If there was a lightening strike, would such a setup rip a hole in the space/time continuum?
Randell Tarin is offline   Reply With Quote
Old 02-22-2008, 04:15 PM   #2
Rewards Points: 2,350
Yes. Yes it would.
InPhase277
Old 02-22-2008, 07:42 PM   #3
Custom Cabinet Maker
Fer shure and I got the pics to prove it
skymaster is offline   Reply With Quote
Old 02-22-2008, 07:53 PM   #4
For the love of God man, post them!!!
Old 02-22-2008, 09:10 PM   #5
electrical contractor
Rewards Points: 150
I dont know if it actualy would, but i bet it would sure sound like it did.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-22-2008, 11:00 PM   #6
Union Electrician
goose134's Avatar
Actually, no. In switch gear rooms often times ground rods will be sunk in all corners, bonded together. The transformer vault (POCO feed) will have perimiter ground, then a bond to the building ground. They will make you keep sinking rods and running cable between them until they get their 25 ohms. One room we had to sink 5 rods. It was maybe 400 sq.feet
And in case you were wondering 1.21 gigwatts x 25 feet #4= time warp.
goose134 is offline   Reply With Quote
Old 02-23-2008, 06:42 PM   #7
Sparrky
Kingsmurf
Whoa . . . .on tyhe first post I was thinking . .Wholly Smokes what are they grounding? Three MIle Island
reading on . . . . .apparently so
but considering what suicide it is to drive ANYTHING into the ground 8 feet around here maybe its a thought . . . . .mmmm #4 is going for what a foot now?
Kingsmurf is offline   Reply With Quote
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
