Old 09-05-2008, 08:28 PM   #1
Overheated Wire Connections In Stove Top
Top of electrical range is overheating, therefore wire connections in elements are loose.
Question : Is there any protection available ?
Like for example, sheet metal, to create a double space ( between socket connection & stove top ) for cooling. or anything to this effect.
Thank You !
chef is offline   Reply With Quote
Old 09-05-2008, 08:34 PM   #2
You might have this backwards.
Wire connections in elements are loose, therefore top of range is overheating.
220/221 is offline   Reply With Quote
Old 09-05-2008, 08:45 PM   #3
No I Dont, See What Happen:When The Element Is On
The Heat from ( let say frying pan ) heats up the top
and the socket is real hot, thetefore the wires are burn
and loose.
Old 09-05-2008, 09:36 PM   #4
Electrician
and loose.
See, they ask for help and your still wrong.
chris75 is offline   Reply With Quote
Old 09-05-2008, 11:29 PM   #5
Electrician
SD515's Avatar
Sorry 220...not laughing AT you at your expense...laughing WITH you...
Old 09-06-2008, 07:35 AM   #6
i do appliance repair. a common problem are those burner receptacles. you have to replace burner AND receptacle also repair any burned wiring. do not use oversize pans on Hi heat.
Jacques is offline   Reply With Quote
3 wire stove connection bgoldie Electrical 13 03-01-2011 01:29 PM
Stranded wire connections Cossack Electrical 7 03-14-2008 11:56 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Stove Top wire capt2 Electrical 8 10-05-2007 02:41 PM
3 wire connection for new kitchen stove rjniles Electrical 4 09-13-2007 01:59 AM
