Overhead Service To Buried Line - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 09:31 AM   #1
Indentured Servant
Overhead service to buried line
Going to attempt to do this myself. Will need to rent a ditch witch and bury the line. Any tips or things to make this easier/cheaper? I need about 75 feet of line.
jackpine is offline   Reply With Quote
Old 08-30-2011, 09:36 AM   #2
I=E/R
a7ecorsair's Avatar
Since you used the term "Service" are these service conductors or breaker protected feeders?
a7ecorsair is offline   Reply With Quote
Old 08-30-2011, 09:39 AM   #3
Code05's Avatar
Rewards Points: 1,104
1. Call Miss Utility and have everything marked.
2. Follow minimum depths in 300.5.
3. Make sure cable is correct size and type.
4. Use correct burial marking tape in trench.
5. Back fill dirt should be clean of rocks and debris or use sand.
6. Use s loops at each end for earth movement.
Code05 is offline   Reply With Quote
Old 08-30-2011, 10:56 AM   #4
Rewards Points: 3,130
Can you legally do this? I couldn't where I live. I dug the trench and laid the conduit, but had to have the power company pull the conductors.
Old 08-30-2011, 11:00 AM   #5
I=E/R
a7ecorsair's Avatar
So they are service conductors.
You need to be more descriptive of your project. Where is the meter and where is the main disconnect?
Old 08-30-2011, 11:13 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Jackpine.,
As one of our member mention here please try to clearify it little more what are you try to dig in the conductors ??
If this is a service drop and want to change to underground you have to talk to the POCO they have few strict guideline to follow and follow Code05's part as well and the POCO will give you the correct specs for lateral run { underground drop } and most case they will install the lateral run sized for 200 amp service which it is common.
If this will be used between the house and the garage or shed then there is few guide line you have to follow.,,
min depth is 24 inch direct burial or in conduit { I know in wisconsin requiired both at the same depth unless you have 20 amp 120 volt GFCI circuit then it can be shallower it simair rules we have in France }
If more than one circuit you will need then you will have to bring out single MWBC circuit and if you have any exsting circuit like old overhead circuit that have to be removed.
If you have exteitour {outside } luminaires that is contolled by either house or garage you will have to pay attetion to the source location { this part is getting strict nowdays due you will need a common disconnect switch which I will mention in a moment }
All the detached building you will need a disconnect means so a simple double pole or single pole or subpanel with backfeed main breaker { if more than 6 circuits }
Of course with detached buildings you will need ground rods
Let us know what your plans then we can assit you with few tips and info to help you with it and belive or not get the permit for this project this will realy save your rear end.
If more question just holler in here one of us will help you on it.
Merci,
Marc
Old 08-31-2011, 07:06 AM   #7
Indentured Servant
Power from the meter pole to my house is overhead. I am putting a dormer in right where this overhead line comes in. I plan on burying the line from the meter to my house. The overhead is inclosed in conduit and extends down the house to several feet above grade on the block wall just outside of my service box on the inside.
Service entrance for farm house. jptkaczyk Electrical 14 02-12-2011 05:24 PM
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 10:37 AM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 12:23 PM
Buried Supply Line ? Bob10 Plumbing 28 06-06-2008 01:02 PM
