Overhead Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 04:53 PM   #1
Overhead outlets
We will be pouring a slab soon and I want plugs in the floor in living room and wiring for island in kitchen... My husband said retractable outlets from the ceiling? Is there such a thing? He said you pull something from the ceiling and when done it will retract back.
Tmitch46 is offline   Reply With Quote
Old 08-16-2011, 05:03 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
In the kitchen the receptacles have to be withing 18" of the counter surface. I would not accept ceiling mounted receptacles as the required wall receptacles. Check with your local EI.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2011, 05:16 PM   #3
Rewards Points: 6,652
Only in a commercial application. In a home they would stick out, unless you lived in a loft that was made up to look like the showrooms in a Ikea store.
Old 08-16-2011, 06:05 PM   #4
Master Electrician
Rewards Points: 3,870
The correct number is 20".
brric is offline   Reply With Quote
Old 08-16-2011, 06:26 PM   #5
electures's Avatar
Thanks. Shot from the hip.
Old 08-16-2011, 06:29 PM   #6
electures's Avatar
Use floor boxes. They are available with power, phone, data and CATV. And combinations of all. He can lay smurf pipe on the ground under the slab and poor concrete right over it.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 09:19 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
