Overhead Lighting Run To Lights First Then Switches, 14/3 To Both Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 08:19 PM   #1
Rewards Points: 150
Overhead lighting Run to lights first then switches, 14/3 to both switches?
A friend of mine is an electrician and he told me what he thought was the best way to run my overhead lights. I already have all of my recepts. done etc.
He told me to run from the box to bedroom 1 overhead fixture, bed 2 overhead fixture and then bedroom 3 overhead fixture. Now he said to run a 14/3 from the switch to the overhead fix. in bedroom 3 and from the other switch in bedroom 3 to the overhead fixture with seperate 14/3. The same scenario applies to bedroom 2.
However bedroom 1 only has 1 switch so he told me to just run a 14/2 to the switch from the overhead fixture.
My books show a different way to wire going to the fixture first. It shows only one 14/3 and then a 14/2 but I have 1 14/3s from the fixture. Does anyone know how to wire this and is it correct? Thanks.
twilightcall is offline   Reply With Quote
Old 07-09-2008, 08:55 PM   #2
Electrician
Why not just call your buddie back up and have him re explain it?
Personally, why not just feed the switch from the plugs and just hit the light, its simple, easy and you'll be done before you know it. Besides all that, one less splice you can mess up.
chris75 is offline   Reply With Quote
Old 07-10-2008, 07:01 AM   #3
Rewards Points: 150
How do you run 1 wire to 3 rooms feeding the switch first? I can see doing 1 circuit for each room and feeding the switch but how would you run all 3 rooms on the same breaker and feed the switch first.
Old 07-10-2008, 08:56 AM   #4
Licensed Pro
Panel (14/2) to sw 1, to sw 2, to sw 3. Switch loop from each switch to fixture using 14/2 if light only, 14/3 if fan and light. Simple, clean, quick.
Old 07-10-2008, 05:18 PM   #5
Electrician
I was assuming the bed rooms were already fed, but guess I dont know what I cant see, thats what make these sites so funny, giving advice without really knowing whats going on...
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
2 switches - 14/3 cable scottmatt Electrical 25 12-11-2007 10:24 AM
Fluorscent Lighting jerryd Electrical 8 11-14-2007 04:53 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
lighting automation christy123 Electrical 10 03-07-2007 05:18 PM
