Overhang Discovered To Have "Indoor Only" Pot Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 01:02 PM   #1
Unhappy
Overhang Discovered to Have "Indoor Only" Pot Lights
We discovered recently that an exterior overhang and the front porch had
"Indoor Only" pot lights installed by the Electrician who was on the job for our remodel project.
The new Electrician told us this is illegal, and he changed them out immediately.
The cost to replace them was high as we also had to bring in a carpenter to tear out most of the decorative bead board.
Any Electricians out there who can give their opinion?
ConsumerTalk is offline   Reply With Quote
Old 03-27-2011, 01:08 PM   #2
Licensed electrician
Rewards Points: 1,630
The electric code requires that things be used according to the instructions and any listing or labeling requirements. You said that indoor only lights were installed outside. Your electrician was correct.
Old 03-27-2011, 03:32 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,942
I'm not sure that's an "outdoor" installation. If it's not subject to water or dampness, then there's really no difference between the underside of a porch overhang and a ceiling in your living room. Lights listed for "outdoor" use are rated for damp or wet location. Those ratings are not required for this installation. I think there is at least a valid argument that the installation was not improper.
mpoulton is offline   Reply With Quote
Old 03-27-2011, 05:46 PM   #4
Electrical Contractor
kbsparky's Avatar
Outside, under an overhang, or in an open porch area is considered a "damp" location. High humidity and condensation can occur in such locations, and any equipment located there must be able to deal with this condition.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
mpoulton (03-27-2011)
Tags
electric code
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
