Over Or Under Insulation In Attic? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 01:25 PM   #1
Over or under insulation in attic?
Is it better to run electrical wires over or underneath the insulation in the attic?
PhillyRyan is offline   Reply With Quote
Old 08-23-2010, 08:17 PM   #2
dSilanskas's Avatar
six on one hand half dozen on the other. It doesn't matter but it looks better if it's under.
dSilanskas is offline   Reply With Quote
Old 08-23-2010, 09:08 PM   #3
Rewards Points: 20
Your cable may need to be derated(increased in gauge)when run on the hot side of the insulation.
daveb1 is offline   Reply With Quote
Old 08-23-2010, 09:18 PM   #4
dSilanskas's Avatar
V
Derating your wires due to the insulation in a house? Im sorry but that has to be the ??????????? i've ever heard....
Last edited by beenthere; 08-24-2010 at 03:11 PM. Reason: Rephrased teh staement to be more polite
Old 08-23-2010, 09:47 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,904
Originally Posted by dSilanskas View Post
V
Derating your wires due to the insulation in a house? Im sorry but that has to be the most stupid thing i've ever heard....
Um, what? Ambient temperature is a necessary factor to consider for derating. If putting the wire on the outside of the insulation exposes it to very high temperatures in the attic, it may need to be derated. With that said, it will not USUALLY be necessary to derate because of this, and most people ignore it.
mpoulton is offline   Reply With Quote
Old 08-23-2010, 09:58 PM   #6
dSilanskas's Avatar
Magnetic everyone ignores it because no need to derate in an attic. If it was such an issue than why isn't there ever issues with the way we (electricians) wire houses. Never ever have i had to derate while running my wires in attics. Its just not needed
Old 08-24-2010, 09:10 AM   #7
It seems if you put it over the insulation then it would be exposed to much higher temperatures but if you bury it under the insulation so that it's almost right against the cooled part of the house, then it wouldn't be able to disipate the heat that's generated in the wire itself due to current. So which is worse, the ambient heat of the attic or the heat from the current??
Old 08-24-2010, 09:59 AM   #8
Rewards Points: 1,452
At the attic floor the temperature should not be too bad. I would just go by the NEC (RE cable spacing) and not bother to derate the cables simply because of the attic temperature.
AllanJ is online now   Reply With Quote
Old 08-24-2010, 12:36 PM   #9
Registered User
Rewards Points: 5,256
"Secure within 12" of box & maximum 4-1/2' intervals --- 3702.1 '06 IRC 314.17C '08 NEC(not to the insulation) right below de-rating from the manufacturers stamp: http://books.google.com/books?id=eLo...0attic&f=false
Remember the boards within 6 &7' of the access.
Be safe, Gary
Old 08-24-2010, 03:10 PM   #10
An old Tradesmen
Rewards Points: 6,588
V
Derating your wires due to the insulation in a house? Im sorry but that has to be ??????????? thing i've ever heard....
Strange. Wire is rated by the ambient temp it is installed in.
While low draw circuits aren't usually effected. Higher current drawing devices are.
Old 08-24-2010, 03:24 PM   #11
zpm
yeah, right
That depends on where you live.
For my house, on a 100 degree day with the A/C running
The temp at the peak can top 125.
The temp above the insulation can hit 105.
The temp under the insulation against the sheetrock is about 80.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-24-2010, 10:36 PM   #12
Inspector/Instructor
codeone's Avatar
V
This has already been taken into account with NM cable having to be rated out of the 60 degree column. and now for se and ser when run in the interior of a house in insulation with the 2008 NEC.
codeone is offline   Reply With Quote
Attic Insulation gruntman Roofing/Siding 12 12-04-2010 10:01 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 05:36 PM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 11:17 PM
Finishing Attic, insulation question pjgsteelers Remodeling 1 07-13-2010 02:59 PM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 06:06 PM
