Over The Range Microwave - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 08:35 PM   #1
Over the Range Microwave
i have a GE Spacemaker microwave, and i am trying to remove it from the wall. i took the two screws from the top...thats as far as i got. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you,
-Armando
v36padron@aol is offline   Reply With Quote
Old 03-14-2009, 09:09 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
There should be at least three screws inside the upper cabinet. Then the unit will tilt down and unhook from the back plate at the bottom.
If you can find them online the instructions will show it clearly.
Old 03-14-2009, 09:27 PM   #3
SDC
SDC's Avatar
http://products.geappliances.com/Mar...e=49-40538.pdf
should be similar.
Good luck
SDC is offline   Reply With Quote
Old 03-14-2009, 10:20 PM   #4
Custom Cabinet Maker
V36: HOLD UP!!!!!!!!!!!! OK First yes take out the screws thru the cabinet. NEXT, remove the plastic grille, dont lose the screws! INSIDE you will see 2 large slotted shafts, they are quikk disconnects: HOLD ON TO THE MW, GIVE THEM A TURN AND THE MW WILL ROTATE DOWN then you can disconnect it fron the backplate by slightly lifting up on the back bottom, it hooks onto that plate
skymaster is offline   Reply With Quote
Can't remove Whirlpool Over the range Microwave kzukowski Appliances 18 06-18-2016 05:20 PM
GE Profile over the Range Microwave BrentH Appliances 5 01-08-2009 11:25 PM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 01:01 AM
Wall vent for over the range microwave JoeClark Building & Construction 3 11-29-2008 01:11 PM
