Oven Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2008, 07:53 AM   #1
oven wiring
Am installing 15a 240v oven with 10-3 wire and 30a breaker. Very cramped space in cabinet & it seems a plug would be easier than hard wiring.There seem several plugs available. Which if any is proper? Is wire & breaker choice correct?
stan 41943 is offline   Reply With Quote
Old 03-23-2008, 08:57 AM   #2
Electrician
Rewards Points: 778
If your stove is truly 240V 15A(which sounds small to me) why are you wiring with 10-3 and a 30A breaker.
Find your stoves nameplate and get us the info off of there like the voltage, amp draw, and the watts if it is on there. Then we can tell you what size breaker and wire to use.
darren is offline   Reply With Quote
Old 03-23-2008, 10:25 AM   #3
"total rating 3.7 kW, total Amps 16" Also plug vs. hard wire. Thanks!
Old 03-23-2008, 10:46 AM   #4
Electrician
The 10-3 is fine, but you'll need a 20 amp breaker, as far as installing a cord, if that oven already has a whip installed I doubt you can modify it, but if it does not, then its legal to have it cord and plug connected, but the cord needs to be rated for the temperature of the space in which it is located.
chris75 is offline   Reply With Quote
Old 03-23-2008, 12:31 PM   #5
Thanks guys. Hardwire & 20a Fuse.
Old 03-23-2008, 01:33 PM   #6
Electrician
Rewards Points: 778
If you have not bought the wire you could wire this with 12/2(if it is only a 240V load, if it is a 240/120 load you will the neutral. That would save some money on wire but if you have ran your 10/3 already you are good to go. If it is a 240V you can cut the white wire right off in that cable.
Old 03-23-2008, 01:44 PM   #7
Rewards Points: 2,350
No, you can't.
InPhase277
Old 03-23-2008, 07:20 PM   #8
Electrician
So your the guy that does that!
Old 03-24-2008, 09:26 AM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
Man, I hate that!
jbfan is online now   Reply With Quote
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Oven wiring rodsteryz Electrical 1 12-26-2007 02:26 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 06:05 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
