-   -   oven wiring (http://www.diychatroom.com/f18/oven-wiring-18860/)
stan 41943 03-23-2008 06:53 AM
oven wiring
Am installing 15a 240v oven with 10-3 wire and 30a breaker. Very cramped space in cabinet & it seems a plug would be easier than hard wiring.There seem several plugs available. Which if any is proper? Is wire & breaker choice correct?
darren 03-23-2008 07:57 AM
If your stove is truly 240V 15A(which sounds small to me) why are you wiring with 10-3 and a 30A breaker.
Find your stoves nameplate and get us the info off of there like the voltage, amp draw, and the watts if it is on there. Then we can tell you what size breaker and wire to use.
stan 41943 03-23-2008 09:25 AM
"total rating 3.7 kW, total Amps 16" Also plug vs. hard wire. Thanks!
chris75 03-23-2008 09:46 AM
The 10-3 is fine, but you'll need a 20 amp breaker, as far as installing a cord, if that oven already has a whip installed I doubt you can modify it, but if it does not, then its legal to have it cord and plug connected, but the cord needs to be rated for the temperature of the space in which it is located.
stan 41943 03-23-2008 11:31 AM
Thanks guys. Hardwire & 20a Fuse. :thumbsup:
darren 03-23-2008 12:33 PM
If you have not bought the wire you could wire this with 12/2(if it is only a 240V load, if it is a 240/120 load you will the neutral. That would save some money on wire but if you have ran your 10/3 already you are good to go. If it is a 240V you can cut the white wire right off in that cable.
InPhase277 03-23-2008 12:44 PM
No, you can't.
InPhase277
chris75 03-23-2008 06:20 PM
So your the guy that does that!
jbfan 03-24-2008 08:26 AM
Man, I hate that!:censored:
