Oven Repair - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 02:40 PM   #1
oven repair
I have a Tappan Millenia gas stove and the oven wont light. The glow bar glows orange with just a small section glowing bright yellow. do I need a new glow bar? oven is 12 years old.
hanky is offline   Reply With Quote
Old 01-08-2012, 02:45 PM   #2
MarginallyQualified
Rewards Points: 2,464
From over here...that sounds like a terrific point to start from.
hth
Old 01-08-2012, 02:47 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,856
That could be normal, or could be weak. Is there good gas flow? If you put a lit match near the igniter, does it light?
mpoulton is online now   Reply With Quote
Old 01-08-2012, 02:56 PM   #4
no I cant hand light, I believe its because of gas safety valve may not be opening if glow bar is not hot enough? does that sound right?
Old 01-08-2012, 02:57 PM   #5
top burners work fine so i know gas is getting to stove
Old 01-10-2012, 01:39 AM   #6
yep that was it replaced glow bar today and oven fired right up simple job 20min. $65 dollar part saved on new stove or at least house call
Old 01-10-2012, 02:38 AM   #7
Very good! Thanks for following up with the solution - we often never hear what happened to people who come here for information...
The Following User Says Thank You to mpoulton For This Useful Post:
hanky (01-11-2012)
Old 01-10-2012, 07:27 AM   #8
Rewards Points: 1,294
Pretty common problem on glowbar ignition ovens. There is a circuit that senses current flow to the ignitor. If it is out of range it will not allow gas flow. Confuses a lot of people as they see the ignitor glowing and think it is OK.
danpik is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
oven repair taco 2 Appliances 1 10-16-2011 06:33 AM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
1981 GE Medallion Electric Wall Oven Repair / Tune-up Reilley Appliances 5 01-18-2009 01:10 PM
